Old 12-05-2016, 12:19 AM   #1
matt_field
matt_field's Avatar
Stock 67-72 tach with 12v?
Hey guys, I've searched and can't find this answer. Can I use my stock tech with my 91.5 12v? I've seen some of those adapters for your dampener, with diff pulse readings. Hopefully someone has done this. Thanks!!
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 12-05-2016, 10:10 AM   #2
BigBlockBurris
BigBlockBurris's Avatar
Re: Stock 67-72 tach with 12v?
Matt,
Do you happen to have any more pics of your swap?
Gorgeous truck!!!
BBB
BigBlockBurris is offline   Reply With Quote
Old 12-05-2016, 10:00 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
If you have a pick up sensor and have 4 notches milled into your vibration dampner, you can get it to work. You have to solder in a 1k ohm resistor in between the signal and pos wires on the pick up sensor harness to get it to work. I'll have to dig up my notes. I haven't gotten to that on mine yet.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-06-2016, 11:29 AM   #4
matt_field
matt_field's Avatar
That'd be great Ryan!! I believe I do have all the above.
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 12-06-2016, 11:31 AM   #5
matt_field
matt_field's Avatar
With this I phone I can't put multiple pics on one reply
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 12-08-2016, 09:36 AM   #6
BigBlockBurris
Matt,
Thank you very much for the pics!
I am getting ready to start a swap into a 1972 C-30 and I am just trying to get all the info I can.
Did you use the stock second gen intercooler?
Thanks!
Alex
Old 12-08-2016, 02:18 PM   #7
matt_field
matt_field's Avatar
Yup, 2nd gen intercooler and had it shortened. To tall , it hit the good latch
1967 swb 2wd 427bbc
1968 4wd shortbox
