Old 12-09-2016, 12:06 AM   #1
Custom/20
Custom/20's Avatar
Did I just get a spun cam bearing?
Title says it all....
It's coming from right in the middle of the engine.
Video: https://youtu.be/5NSLeAGFWBs
Custom/20 is offline   Reply With Quote
Old 12-09-2016, 12:16 AM   #2
Toms67
Toms67's Avatar
Re: Did I just get a spun cam bearing?
Did you lose any oil pressure? Could it be lifter or valvetrain noise?
Toms67 is offline   Reply With Quote
Old 12-09-2016, 12:18 AM   #3
Custom/20
Custom/20's Avatar
Its always past 60 when cold and it looks like it dropped. I don't want to even start it now.
Old 12-09-2016, 12:21 AM   #4
Toms67
Toms67's Avatar
I should've watch the video first. Hard to tell from the sound quality. The noise is it coming from down below is it? Is it automatic or standard? A loose flywheel or bad torque converter?
Old 12-09-2016, 12:23 AM   #5
Custom/20
Custom/20's Avatar
It's coming from the front of the engine. It was much louder when it first started and it's more up top.
Old 12-09-2016, 12:24 AM   #6
Toms67
Toms67's Avatar
Longshot. Wouldn't be lucky enough to be a water pump?
Old 12-09-2016, 12:32 AM   #7
Custom/20
Custom/20's Avatar
I'm gonna let it warm up all the way and check the oil pressure and post back. I know where it's at when idling when hot so if it dropped I'll know. It is running fine but that noise....
Old 12-09-2016, 12:57 AM   #8
Custom/20
Custom/20's Avatar
Alright so I've been driving it around our development for a half hour and the oil pressure seems fine. It hasn't moved lower then it always is when warm. It's right at 30. Could cold belts cause that? It is snowing here.
Old 12-09-2016, 06:41 AM   #9
Toms67
Toms67's Avatar
Last time I had a noise like that disappeared. I let the cat out of the radiator shroud. LOL. Going back and watch Colombo. Good luck.
Old 12-09-2016, 06:48 AM   #10
Custom/20
Custom/20's Avatar
Luck was definitely on my side today! Thank God.. I just drove the truck around for over 2 hours drifting in the snow! Oil pressure at idle after all the drifting in a large empty parking lot and and our development and the oil pressure is still the same as always. About 40lbs on the gauge at idle! So happy!
Old 12-09-2016, 07:33 AM   #11
hamjet
hamjet's Avatar
loosen up the belts and remove them. then start it. it won't hurt anything for a few minutes, to see if noise goes away...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 12-09-2016, 07:42 AM   #12
Custom/20
Custom/20's Avatar
Thumbs up Re: Did I just get a spun cam bearing?
Yeah, once I let it warm up the sound just started to go away the warmer the engine got. Haven't heard it since it warmed up. I've drove around , let it sit in the 25 degree weather to where the engine was cool and drove it again and it hasn't made a peep, even after a hour of drifting in the snow... It must have been the belts I guess. Oil and temp are all normal and it's running smooth on all cylinders.
Old 12-09-2016, 01:17 PM   #13
toolboxchev
I agree with that one right away. First place I would look after the excellent suggestion.
toolboxchev is offline   Reply With Quote
Old 12-09-2016, 07:25 PM   #14
BILT4ME
I thought it sounded like an alternator bearing.
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
Old 12-09-2016, 09:27 PM   #15
garyd1961
I have seen belts get wet and when they dry out they get hard and sound like a bad bearing. Maybe try some belt dressing on them. I used WD40 in my younger days but wouldn't recommend it now.
garyd1961 is offline   Reply With Quote
Old 12-09-2016, 10:54 PM   #16
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Judging from the video your belts are a size too small. Replace your belts with a set that fit flush or just above the outer edge of the pulley's. While the belts are off, take the time to clean the pulley's and if that slipping belt polished the inside of the pulley, use a file to deglaze the shine and burnt rubber. Once a belt slips inside of the walls of a pulley, it's just a matter of time before it looses it's grip and over tightening will only wear out alt. or power steering pump bearings... http://www.bdi-usa.com/FileUploads/C...e_posters_both[0].pdf
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
bearing, cam, spun
