Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-04-2017, 01:24 PM   #1
hotsam
hotsam's Avatar
Just A few plans for my 72' swb 4x4 Going Big Block !!
Only pic I have.. more to come
hotsam is offline   Reply With Quote
Old 01-04-2017, 01:43 PM   #2
hotsam
hotsam's Avatar
Re: Just A few plans for my 72' swb 4x4
Been after this truck for a while. Was my neighbors daily driver for years when I was younger. He traded his green and white '66 swb Chevy for it in 1984 because he was needing a 4x4. I would tell my dad that I would own it someday as we would pass him every morning on his way to work, while I was heading off to school. Well, after a few years of inquiring off and on, it happened last year... I had the dmv send me back his title showing he bought it in 84 just for keepsake. He always ran 33x12.5s on it when he replaced tires, but I have replaced the old dry 33s with 31x10.5s. I think they look a little less "Tonka" truck on it ?? I will update pics with new tires as soon as I get a few. I drive it every day to work and it's my driver unless I'm in my work truck. It was originally blue, but all numbers match on chassis and drivetrain. It's a 350/3spd. On column. 4bbl. Carb, 4x4. Engine is a little tired, and gearing is high. Trans SUCKS for towing so I'm setting in my 454/sm464/205 out of the square I just sold as a roller. As I use the truck to tow my other toy as well.
Old 01-04-2017, 02:41 PM   #3
hotsam
hotsam's Avatar
Sorry about another post.. Also a typo thats an sm465 trans I am installing. you can already see im no computer guy.. Trying to figure out picture loading ?? Other than a light camper, or mower trailer this is what I will mainly be pulling when the truck is at work doing what it was intended to do.. I have to get some recent pics of both the truck and car. The car is alot different now. The pic was from a few years ago. I kept all the engine mounts and engine crossmember out of the square body i read here they work better, but have not decided if I will use them or not.. Any input ? Thanks
Old 01-04-2017, 05:12 PM   #4
El Dorado Jim
nice truck, love the 4x4's going to have an awesome drive train with the 454,sm465 and 205....I have a 72 K20 ,with a 350,sm465 and 205, would love to have a swb K10 also
El Dorado Jim is offline   Reply With Quote
Old 01-24-2017, 10:51 AM   #5
hotsam
hotsam's Avatar
Snapped a few pics of my truck this morning when I got to work. Haven't started the swap yet but should get started in a couple weeks.. I just love driving it !!
Old 03-26-2017, 08:11 AM   #6
hotsam
hotsam's Avatar
Hey guys ! It's been a little while and I've been procrastinating on my engine swap... But fate has presented me with no choice now so here it goes. Last Sunday morning I was heading home and it started a ticking ,then a miss, then popping through the intake and carb. I figured cam failure. I felt the exhaust manifolds when I got home and singled out the cylinder culprit. I pulled the valve cover and found a broken rocker arm was the problem. Easy fix right... I zipped a new rocker on adjusted and engine runs like a sewing machine again. After firing was when I realized why the failure took place. I have no oil at the rockers they are dry as powder. The engine holds great oil pressure and the lifters are primed and not collapsed no chattering no noise. I'm going for a long shot and assuming push rod tubes may be blocked from nasty years of crummy oil and lack of normal p/m. After the engine runs for a while a couple do drip some oil. I thought about investigating farther but I'm just gonna swap now before I have total destruction of my little engine. It still sounds and runs great so time for a freshen up and I'll use it in one of my other toys one day. I'll post progress pics as I go. Time for Operation Big Block 4 spd. Swap
Old 03-26-2017, 11:02 AM   #7
fakerwade
fakerwade's Avatar
Cool looking truck!! Let the engine swapping begin!!
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 04-06-2017, 08:01 AM   #8
hotsam
hotsam's Avatar
Had a couple hours between repairs in the garage yesterday ,so I got started and pulled the small block out.
Old 04-06-2017, 08:14 AM   #9
hotsam
hotsam's Avatar
By the way, all of the push rods were clear and could be seen through and the rocker holes were the same.... I'll diagnose this oiling problem further and post pics when I do the small block tear down. But for now its on with operation Big Block!!
I'm thinking of just moving the stock crossmember forward a couple of inches to the front set of holes on the driver side and drilling the rest new, but I also have every piece of the 85 member and engine mounts. Any info , advice, or pics from someone who has done this and been here would be greatly appreciated !! I've done some searching and I have some ideas but experience is the best tool... I did notice the frame tapers in a little as it comes toward the front ?? Also my 454 has a Milodan oil pan that I bought special when I had it in my 55' so I think that will help a TON on clearance too... I'll post pics of the BB soon.
Old 04-06-2017, 08:29 AM   #10
hotsam
hotsam's Avatar
Thanks for the replies I do love my ole pickup... And it amazes me the quality of work and the awesome, nice trucks I see go together here. This place is great !! My truck has something I want you guys that know these trucks inside and out to look at for me.. The driver side front, front and rear spring hangers have some pieces on and near them I'm not sure of. The front looks factory stamp welded its a flat strap that runs the width of the hanger. The rear may be home garage made, but it bolts behind the spring to maybe serve as a stop ?? The spring has never touched it though ?? Here's the pics. I do know the rivet replaced with the bolt at the front is not factory. Its in the pics. You can tell by a little wear that The hanger got a little loose on the frame and the put a couple bolts in the rivet holes... Thanks again
Old 04-06-2017, 08:38 AM   #11
hotsam
hotsam's Avatar
Oh, and the wife and I picked this up this week to pull behind the 72' Its a 1969 Yellowstone Cavalier 16S . She wants to paint the stripe turquoise , but I think they will make a nice pair check out the neat little propane light inside.. The older stuff is just so darn cool !!
Old 04-11-2017, 08:21 AM   #12
hotsam
hotsam's Avatar
Hey guys... So I've been doing a little brainstorming... Has anyone done the big block swap and left the 3 speed on the column in their 4x4 ?? I'm actually thinking about just cleaning everything up really nice and painting it up fresh and using the 3 speed setup ?? I think it would be neat and a little different.. I think no more towing than I do the torque of the 454 would overcome the gearing issues in the trans 1st and Reverse and diffs. I just don't know about clearance issues with the linkages and such.. I use my power stroke for any serious towing anyway.. Just a thought.. Any experiences shared would be appreciated..
Old 04-11-2017, 12:22 PM   #13
webfoot
That is a neat old camper! Sorry, can't help with the BB swap stuff, both mine have been SBCs.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 04-11-2017, 12:29 PM   #14
hotsam
hotsam's Avatar
Thanks webfoot... We thought it was pretty neat. My wife is in a frenzy wanting me to finish it for its maiden voyage... Just a few more days I hope!! I have too many projects haha. I noticed you have a GTO. I have a 67 400 factory 4 spd. Bought in high school.. I love poncho power !!
Old 04-11-2017, 04:27 PM   #15
El Dorado Jim
those pieces are factory,dont know why there is a bolt in yours...I can't remember why they put those extra pieces on there,but mine has them as well, hopefully someone will get in on this and let us know...
Old 04-11-2017, 05:27 PM   #16
hotsam
hotsam's Avatar
Thanks Jim... I didn't think they looked homemade ?? Only the driver side has them too.. hopefully someone will chime in. I gots to know...
Old 04-14-2017, 03:47 PM   #17
hotsam
hotsam's Avatar
Well, I got a few more minutes today and jumped over to the bay my pickup is in.. After studying a while on it, I'm gonna go ahead with my original plan. I'm using the 73-87 mounts and engine crossmember. I don't want to beat any on the firewall and I already saved these from a truck I junked out anyway... If I use the 72 stuff , the engine crossmember will be directly over the diff without much clearance when I move it forward 2 inches. The newer member will be in front of the diff and work out better I think. Also it's getting the 4 spd after all .... the 3 speed linkages will be right in the way of the exhaust and I just like the 465 better. Pics to come soon of measurements and layout..
Old 04-18-2017, 04:35 PM   #18
hotsam
hotsam's Avatar
Got a little more done today... We'll see how the engine fits tomorrow then back out for a good cleaning of everything. If it fits nice, ill post exactly my fitment of the later crossmember and engine mounts with all pictures. It moved it foward right at 2" or just a touch more...
Old 04-18-2017, 04:38 PM   #19
hotsam
hotsam's Avatar
At the present time there are no extra holes in the frame I used three existing I will have to drill 6 if it works
Old 04-18-2017, 04:44 PM   #20
hotsam
hotsam's Avatar
Re: Just A few plans for my 72' swb 4x4 ...Big Block Swap
Tried to edit my thread title ??
Old 04-18-2017, 07:00 PM   #21
hotsam
hotsam's Avatar
Re: Just A few plans for my 72' swb 4x4...Big Block Swap
Pic from passenger side
Old 04-18-2017, 08:18 PM   #22
junksaver
If you don't have a short water pump set up, you may have a clearance issue with the lower pulley and the front frame crossmember.
I'm following along.
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 04-19-2017, 09:59 PM   #23
hotsam
hotsam's Avatar
Well after a long day, and some adjusting and tweaking, its in and buckled down on the mounts and everything fits very nice... No frame trimming, no firewall denting and plenty of clearance everywhere. Thanks for the heads up on pulleys. I had the fan ,radiator, and all mocked up today with no issues. Ill post more info when I have more time tomorrow
Old 04-19-2017, 10:24 PM   #24
hotsam
hotsam's Avatar
Pics
Old 04-20-2017, 08:21 AM   #25
hotsam
hotsam's Avatar
A few more
