01-30-2017, 03:51 PM | #1 |
What a thousand bucks and an education looks like
I decided a couple of months ago that I wanted to put a stock bench seat in my '68 c10. It had a seat out of a late model dodge pickup in it, but I never liked being able to see the headrests through the back window.
I did a little research and learned that there were two different kinds of seats (full foam/spring foam). I started searching on cl until a found a seat that was out of a '70 4x4. I met the guy and looked at the seat, flipped it over and could see the bottom was all foam. I handed him 200 bucks and walked out. Mistake #1......this will come into play later on. I then ordered a 350 dollar houndstooth cover from PUI. I was gambling the foam would be okay in the seat I bought. The seat cover came in after a couple of weeks. In the mean time, I stripped the seat and decided the foam would be okay. I started to put the new cover on and immediately could see it wasn't going to fit. I disassembled the seat further and discovered the seat I bought was out of a '79......Now I'm 550 bucks into this deal and there isn't any turning back now. A couple of days later, I was telling my dad about it, and he said he had a stock bench I could have in the yard of his shop. I checked out the seat, flipped it over and it was a full foam bottom.....score me! After stripping the seat, my dad tells me I need to take it and get it sandblasted and powder coated. I'm thinking to myself, I'm 550 bucks into this deal, I'll be happy with a wire brush and rattle can. However, you can't argue with your dad when he's giving you something, so off to powder coating it goes. 100 bucks later, I pick it it. In the mean time, I knew the new seat was going to need foam so go ahead and order it. 300 bucks. After getting all my parts in, I start assembly, and I discover there aren't two kinds of seats, there are three. And the third one is what I have. Full foam bottom, spring foam back. At this point, I'm not going to be deterred, so I find a full foam back to compare my spring foam to. I discover I can remove the whole spring section of the seat and it modify my new foam and it might just work. So this is what I do. After removing the spring section and cutting down my foam, and paying someone to repair a minor tear repair on the back of the new cover (50 bucks), I am in business. It came out decent, and I did it myself. I still plan to cut down the frame because I sit too high, but that's wont be a big deal..........I hope. |
01-30-2017, 03:57 PM | #2 |
Re: What a thousand bucks and an education looks like
Sorry for your agrivation, but it looks nice!
Greg |
01-30-2017, 04:52 PM | #3 |
ill give you 300 for it. haha looks great
01-30-2017, 05:19 PM | #4 |
I had basically the same story minus the new foam, but it sure does feel good knowing the job was done right!
01-30-2017, 06:44 PM | #5 |
turned out to be pretty nice looking, but costly
01-30-2017, 06:52 PM | #6 |
01-30-2017, 06:53 PM | #7 |
01-30-2017, 08:25 PM | #8 |
Florida Edition
Hats off to you for pushing through.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-30-2017, 09:09 PM | #9 |
01-30-2017, 09:10 PM | #10 |
Yours, too!
Although I went for the water blasting, rattle can primer and semi gloss black. I used burlap against the springs on the bottom and the mesh on the back and a dark gray heavy felt in between the burlap and the foam. Mine is a Spring bottom(thin foam) with full foam back, but I have since purchased a foam bottom/foam back seat which I will swap out in a few months. I get to do it all over again! Hey! |
01-30-2017, 09:16 PM | #11 | |
01-30-2017, 09:20 PM | #12 |
Funny story !
I'am not laughing at you I'am laughing with you ! It really looks nice, good job . Seems like your story is like most of ours , always a curve ball in there somewhere ! Thanks for the laugh ! |
01-30-2017, 09:30 PM | #13 |
01-30-2017, 09:50 PM | #14 |
Similar story here... Previous owner had an "upgraded seat" from a '73-on square-body truck. It was a mouse-piss mess.
Found a correct 67-72 seat frame locally for $50. Thought I could use the foam from that, but it was chewed to hell from mice as well. Ordered new foam and a new seat cover. $800 later I have a beautiful new seat. (Only paid $1200 for the entire truck...LOL)
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
01-30-2017, 09:58 PM | #15 |
That seat came out nice . I feel a lot better about the 300ish dollars I spent on getting mine recovered a few months back.
'71 K1500 Short-Wide '86 K30 C&C '89 Iroc-Z |
01-30-2017, 10:00 PM | #16 |
Oh yeah, forgot to mention... The seat looks great!
01-30-2017, 10:47 PM | #17 |
I like the 67 Camaro...
Do you have a 1972 Plaid Pickup?http://67-72chevytrucks.com/vboard/s...d.php?t=635040 Do you have a 1972 Plaid Suburban?http://67-72chevytrucks.com/vboard/s...d.php?t=635033 Do you have a 1972 Plaid Blazer?http://67-72chevytrucks.com/vboard/s...d.php?t=635035 Your Service Manual: http://67-72chevytrucks.com/vboard/s...d.php?t=558016 SPID Thread http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
01-30-2017, 10:50 PM | #18 | |
01-30-2017, 10:50 PM | #19 |
01-30-2017, 10:53 PM | #20 |
Hey, thanks! That was my first car. We built it when I was in high school (20 plus years ago).
Here's a better picture of it. |
01-30-2017, 11:20 PM | #21 |
The end result looks great, and you can't put a value on such a good education.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
02-01-2017, 12:47 AM | #22 |
I looked around in the KC area to get the front seat of a Studebaker recovered (not even to original spec) and the front seat was going to be $1200 and the rear seat $1000. I about choked, so I found blanket covers and tied them really tight and duct taped the bottom part of the seat before I put it on.
You did ok. It looks GREAT!
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
02-01-2017, 08:27 AM | #23 | |
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 |
02-01-2017, 10:24 AM | #24 |
Not sure I could have avoided having a seat burning party with all of that frustration. Good work pushing through. The seat, the truck and the Camaro all look really nice.
02-01-2017, 10:47 AM | #25 |
Instantly reminded me of this song for some reason. Reminds me of myself as well
https://www.youtube.com/watch?v=-Rrw8VSkrPQ
