Old 02-26-2017, 08:31 PM   #1
tmills213
tmills213's Avatar
4l80 wiring question
I am working on modifying the stock wire harness and chasing wires down per LT1swap's guide. I got all the PCM pins labeled but all the connections that are cut out of the C2 block (all but pink) were chased out and removed. I chased this small bundle to the transmission selector and it seems like too many to remove. did I mess up?
tmills213 is offline   Reply With Quote
Old 02-26-2017, 09:54 PM   #2
racecougar
racecougar's Avatar
Re: 4l80 wiring question
After posting on your FB thread I looked it up to reaffirm. It's just the black/white wire that should remain on the top plug.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 02-27-2017, 12:00 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I don't have a PRNDL/range selector at all. I have none of that.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-27-2017, 01:14 AM   #4
uxdesigner
I'm not sure how different the 4l80e is from the 4l60e but for the 4l60e you ONLY need the black/white wire on the larger plug and keep all 4 on the smaller plug. Based on your picture, you are very close and accurate, looks like you only have (1) extra pink wire that is not necessary.
uxdesigner is offline   Reply With Quote
Old 02-27-2017, 02:54 PM   #5
72MARIO
72MARIO's Avatar
What does the black white wire do for the pcm ? Would these 2 wires be all that's needed to provide the pcm info when the vehicle is being shifted into gear ? I just bought a new harness and it does not have the range selector switch plug. I would like to add it in
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-27-2017, 08:30 PM   #6
racecougar
racecougar's Avatar
http://lt1swap.com/pictures/99_02_sc...aul%202000.gif
The black/white wire on the large plug should route to ground. The four wires on the smaller plug route to the PCM and provide PRND A, B, C, and P signals.
4l80e, wiring harness
