Old 05-01-2017, 09:42 AM   #1
bill3rail
bill3rail's Avatar
Tired of helping my friend with his '69 GMC 4WD
About every two to three years, I help my friend and neighbor tear apart his front passenger side down to hub and try to take up space from a worn out hub.
The outer bearing race does not properly fit in the hub! My uneducated guess is the hub is worn the hell out. After searching for days, I have not found one hub for sale. Does anyone know who sells replacement hubs, or who may have used hubs for sale.
If all else fails, we need to look into replacing the entire front end with a later model, hopefully with disc brakes.
Thank You,
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 05-01-2017, 10:16 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Tired of helping my friend with his '69 GMC 4WD
If you can't find an online vendor go to a salvage yard that has nationwide connections. They can hook up with other salvage yards to see if they can locate one for you. I've done that in the past and it may cost slightly more than if you found one locally but they also guarantee the part.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-01-2017, 11:27 AM   #3
bill3rail
bill3rail's Avatar
I used an online junkyard search site, but none were near me. I printed them out and my friend will be calling them today.
Old 05-01-2017, 03:24 PM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Sometimes Emory cloth and a file will do wonders to clean up any ridges in the hub and on the spindle. I had a small ridge on the spindle that would not let my bearing seat square. Knocked it down, smoothed it out. But you have to maintain the torque on the spindle nut. Jack it up and check for loose bearing with the tire on. Never had a problem since then.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 05-03-2017, 08:29 AM   #5
bill3rail
bill3rail's Avatar
Thanks for the idea, but ridges are not the problem.
The Bearing Race is too loose inside the hub. We need to take up some space.
Thanks,
Old 05-03-2017, 09:00 AM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Spun the race? If so, find a good machine shop that can build surface and has the proper machines to grind back OE specs. That is a hard home shop repair.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 05-03-2017, 12:03 PM   #7
bill3rail
bill3rail's Avatar
Yes, spun race! Unfortunately, the machinists I know are all retired. Even the shop I worked in is closed now.
What later model Dana 44 front ends will fit the '69 4WD?
Old 05-03-2017, 01:00 PM   #8
61K10
61K10's Avatar
Might be one on e-bay. doesn't say what year though.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-03-2017, 01:10 PM   #9
bill3rail
bill3rail's Avatar
Have link, seller name or auction number?
I have been searching SleezeBay, but no luck!
Old 05-06-2017, 07:55 AM   #10
bill3rail
bill3rail's Avatar
Smile Re: Tired of helping my friend with his '69 GMC 4WD
I actually found a replacement hub and two spindles.
Hopefully, no issues when we get them in...
4wd, bearing race, hub, part replacement
