Old 06-01-2017, 07:43 AM   #1
AJC
76 Wrecker
A few weeks ago me and a buddy picked up a 1976 c30 with a Holmes 440 wrecker for $600 bucks. It has seen better days. It looks to have started out as a police wrecker Robbinsdale, MN. It was bought at an auction by a man named Steven, who used it as is personal rig for buying auction cars. Since getting it home it, seems that he had a thing for horns. We have counted 9 so far. We are replacing the clutch currently. Then to un-stick the brakes. As we got it running stepped on the brakes and they never came off.
This thread is mainly to document our progress but advice is always welcome.
AJC
AJC is offline   Reply With Quote
Old 06-02-2017, 08:24 AM   #2
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Re: 76 Wrecker
Love it! I looked for something similar before finding my flatbed. I'm glad I have a flatbed, but still wouldn't mind owning a wrecker someday.
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 06-02-2017, 09:43 AM   #3
flashed
Re: 76 Wrecker
That is pretty cool .
flashed is offline   Reply With Quote
Old 06-02-2017, 07:13 PM   #4
Dads79GMC
Dads79GMC's Avatar
Re: 76 Wrecker
Classic 70's!!!!
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 06-03-2017, 07:11 AM   #5
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: 76 Wrecker
that is awesome I hope you keep this thread updated i would love to watch the progress
put some airbags on the front and it could double as a snow plowing truck
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 06-03-2017, 05:53 PM   #6
AJC
Re: 76 Wrecker
Still having trouble getting the transmission splines to line up into the clutch. Might need to find a transmission jack. As for using it as a snowplow we had about an inch loading it on the ramp.
AJC
Old 06-03-2017, 06:36 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 76 Wrecker
Nice truck... there is a guy around me that has one of these and a flatbed )Squarebodies) still in service
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-03-2017, 06:50 PM   #8
Dieselburb86
Re: 76 Wrecker
I've seen that one on Craigslist! Thought it was the one my dad had a few years ago, but his was a 79.
Dieselburb86 is offline   Reply With Quote
Old 06-03-2017, 08:23 PM   #9
AJC
Re: 76 Wrecker
There is still a number of them in use around here too. Most are the later 81 and up style.
AJC
Old 06-04-2017, 03:27 PM   #10
TrailerTrash
Re: 76 Wrecker
I see a several of these newer styles still in use around here. a few a year on craigslist aswell. i love to see the 73-79s in use
Old 06-14-2017, 02:48 PM   #11
AJC
Re: 76 Wrecker
Good new we got the trans back in. Took a bit to line up the splines. Just need to install the driveshaft and unstick the brakes.
AJC
Old 06-18-2017, 07:28 AM   #12
AJC
Re: 76 Wrecker
Friday we picked up a donor for the cab. Came with some other good stuff. Like a 4x4 sm465 and a np205. The cab will need some rust repair in the cab corners but the floors are there.
Also some questions?
Did they move the shifter forward on the 4x4?
This cab dose not have a removable trans tunnel will that cause problems later?
How dose titling work? This cab is newer and has a 17 digit vin. We did get a title.
AJC
Old 06-18-2017, 09:36 AM   #13
Rickysnickers
Re: 76 Wrecker
I can speak for CA only as far as the title goes. You just plop the cab on the old frame. You would just register it as what ever year the actual cab is, not the rest of the truck, or tow truck in this case.
Old 06-18-2017, 10:49 AM   #14
SamsAutoParts73-87
Re: 76 Wrecker
I'm not sure about a title in your state, but the shifter location will be the same. Most of the trucks after 1981 did not have a removable trans tunnel. It is inconvenient but not really that big of a deal.
Old 08-18-2017, 07:55 AM   #15
AJC
Re: 76 Wrecker
As of yesterday it stops. Clutch is done but may need some adjustment. We gave it a test drive that went well. Found out it has a limited slip which most likely a gov lock. Not sure what the rear gear ratio is maybe 4.10 or 4.56. More work to come.
AJC
Old 09-11-2019, 04:14 AM   #16
AJC
Re: 76 Wrecker
Long time no update. A lot has happened. Swapped cabs. Didn't end up using the red one as we found a better one.
We found the engine had 2 flat cam lobs, so we dug deeper into the engine. It had a ridge at the top thicker then a finger nail and was going to need to be bored over. So instead I used a good vortec block I had. A quick hone, plus new rings and bearings and its good to go. Its running a set of vortec heads and stock L31 roller cam. An Edelbrock Performer intake and 650 carburetor top it off.
We also used the serpentine belt setup from the vortec. The fan sits in the shroud like factory. Photo was from before the shroud was put back on.
Still a lot to do. The wiring is temporary to get it moving, because it's useful for moving stuff around. So we put it back to work. I'm thinking it needs a hand throttle or high idle solenoid to up the rpm for when using the pto winch. It's a bit slow.
AJC
Old 09-11-2019, 11:03 AM   #17
Whamo
Whamo's Avatar
Re: 76 Wrecker
Dig it
Just a Hillbilly in the Hood
http://67-72chevytrucks.com/vboard/s...d.php?t=622194
Whamo is offline   Reply With Quote
Old 09-20-2019, 02:58 AM   #18
AJC
Re: 76 Wrecker
Got some more done on the wrecker. The front grill is installed and bumper back on. Even used the truck to move the bumper inside as it is not light.
Still need to get the cab lights reinstalled, but I'm procrastinating on drilling holes in the roof. Also debating reinstalling the visor as I like it both ways.
AJC
Old 10-11-2019, 11:16 PM   #19
Warrens69GMC
Warrens69GMC's Avatar
Re: 76 Wrecker
Nice!!
Old 10-16-2019, 11:22 PM   #20
LT7A
Re: 76 Wrecker
Looks tough! I hear you on the visor. Not a big fan usually but could seem more appropriate on a wrecker.
Old 10-17-2019, 12:44 PM   #21
daddyjeep
daddyjeep's Avatar
Re: 76 Wrecker
I think the visor would be great on a wrecker.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
