Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 06-30-2017, 05:54 PM   #1
Palmer B
Speedometer cable replacement 65 4x4 suburban
I need replacement speedo cable for 1965 Chevy K10 (4x4) suburban. The cable hooks to the output rear output shaft of the transfer case. The original one was missing, so I don't know the length needed or where to buy. Anyone know for sure the size I need for a 4x4, and a source?
Palmer B is offline   Reply With Quote
Old 07-01-2017, 06:00 PM   #2
bpmcgee
bpmcgee's Avatar
Re: Speedometer cable replacement 65 4x4 suburban
If it's any help, the cable for a 4x4 truck should fit. Classic Industries shows only 1 cable for 47-67, and it's 70" long.
B
bpmcgee is offline   Reply With Quote
Old 07-08-2017, 02:17 AM   #3
padresag
the cable does go to the rear of the transfer case as that is the final drive and doesn't vary there . if you were in the lower range in the transfer case you wouldn't get a true reading if it was mounted to the trans
ron
padresag is offline   Reply With Quote
