Old 08-05-2017, 11:35 PM   #1
OxfordC10
Smile New Tires with Stock Wheels?
Hey,
Wondering what is the biggest size tire I can get for my stock 1970 C10 250 truck is....not too knowledge on this so reaching out to see what you guys think.
Planning to sandblast original wheels....paint deep red to match my sedona red wood bed and put some moon hub caps on. Need new tires and figured I go big!
Thanks!
OxfordC10 is offline   Reply With Quote
Old 08-05-2017, 11:55 PM   #2
mike16
Re: New Tires with Stock Wheels?
I like the look of a 235 r 70 15's on my 72 c 10.
mike16 is offline   Reply With Quote
Old 08-06-2017, 04:38 AM   #3
71sierragrande
Petroleum User
71sierragrande's Avatar
Need more info to get specific. What is your wheel width? By big do you mean tall? Are you at stock height? I have a 265/75/15 at 1/2 ton stock height with room to spare. The first number is width of the tire, and is 24.5 per inch(thats not tread width, but total width). The middle number is percentage of the width on each sidewall. So a 265/75/15 would be approx. 10.8 inches wide. 10.8 x .75=8 inch sidewall. 8 x 2=16 inches for top and bottom sidewalls. 16 inches + 15 inch wheel diameter=31 inch tall tire. (its actually closer to 30 inches, I believe) Keep in mind that total width is about 2.5 to 3 inches wider than tread width, so I have 8 inches of tread width on an 8 inch wheel. As I said, there is room to spare at stock height, so you could go bigger
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 08-06-2017, 08:15 AM   #4
Mike C
Mike C's Avatar
I ran 265 75 16 on zero offset (4" backspace) Alcoas on my 70 GMC c2500. It was stock in front with a 1 1/2" lowering shackle in the rear. That was a good look for that truck. But if you have 6" wide wheels, the 235 is probably a better choice. The 235 85 16 is the same height as the 265 75 16. If you have split rims, I wouldn't keep them...
With the 402 and 3.54 gear that was a good fit as well. You will like the taller tire especially if you have 4.57 in the truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-06-2017, 08:46 PM   #5
bill3rail
bill3rail's Avatar
I am considering going with stock wheel only if I find a decent set of hubcaps to match. Then I may get a set of stock rims.
Currently I have chrome smooth wheels and am not totally fond of them.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
caps, hub, tires, wheels
