08-20-2017, 05:52 PM | #1 |
Bonnie 1971 SWB LSX
Ok so it's been 4 years since I've started this project and it way past time to get a build thread going. I'll try to update it to its current state. Here are some features of the truck.
-1971 shortbed c10 -2009 chevy 6.0, 4l60e, Hydro boost, buckets, tilt, tach, posi, wood bed, boyds tank, entropy radiator, Howell engine harness, AAW chassis harness |
08-20-2017, 06:02 PM | #2 |
Re: Bonnie 1971 SWB LSX
There was not much there when I bought the truck but somehow it was begging for a second chance. After a lot of bodywork, sourcing panels, (3) sets of doors (amazing how a door looks good until you power wash it and rust holes pop through) I was able to send her to the blaster.
08-20-2017, 06:08 PM | #3 |
Was planning on a LS swap from the get go but still hadn't found one so next set was paint the cab.
08-20-2017, 06:11 PM | #4 |
Found a low mileage 6.0! Cleaned up the alum and shot a quick touch up coat on the block.
08-27-2017, 06:32 PM | #5 |
Body, bed and paint
08-27-2017, 06:52 PM | #6 |
Wiring, computer, trans control, DBW gas pedal.
Built a bracket for comp and gas pedal that bolts to original gas pedal mounts and added a 90 degree bracket for stability. Trans control is mounted on firewall tub with 1/4" 20 bolts welded to a fender washer then cut flush to a stud. I cleaned down to fresh metal and glued these with 3M panel adhesive. Used them for mounting the fan and fuel relays as well. |
08-27-2017, 07:06 PM | #7 |
More wiring and what the heck let's get out the buzz saw on some fresh paint. My good friend sold have been a surgeon.
08-27-2017, 07:17 PM | #8 |
Electric speedo
08-27-2017, 07:33 PM | #9 |
Hydroboost
08-29-2017, 11:18 AM | #10 |
what sand blaster do you use. I need for my suburban
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
08-29-2017, 11:45 AM | #11 |
08-30-2017, 11:20 PM | #12 | |
what I really need is a shop that can do my air set up.
08-31-2017, 01:17 AM | #13 |
Just starting a...similar, project. Looking forward to seeing how it goes.
09-01-2017, 12:56 PM | #14 |
Curtb1971,
I'd like to pick your brain about your hydroboost. Could I come by sometime and take a look? I need to get my C10 out for a little burn. Doug
'72 C10 Short Fleet "Praise the Lowered" |
09-01-2017, 02:53 PM | #15 |
Are the heads rectangle port, or cathedral port?
09-01-2017, 09:16 PM | #16 |
That would be fine by me. I'm headed out of town for the weekend but next week I'll be back. I'll shoot you a pm with my contact info. Be a good excuse to knock some carbon off and talk chevy trucks.
09-01-2017, 09:18 PM | #17 |
09-01-2017, 09:20 PM | #18 |
09-01-2017, 10:25 PM | #19 |
This is one good looking truck, where did you score the 6.0?
09-01-2017, 11:41 PM | #20 |
Thanks man, I got it from Al's auto wrecking in commerce city around the beginning of 14'. Al's went out of business a couple month ago. It sucks pretty bad because the guys there were very helpful and the circumstances behind the closing.
09-02-2017, 11:30 PM | #21 |
Damn, andersen's is Greeley has good prices, but beating everyone else to a 6.0 is tough there
09-08-2017, 07:46 AM | #22 | |
Its cool to see Colorado people posting. I never see c10. Keep up the good work and info. ..
09-08-2017, 09:11 AM | #23 |
Proprietor of Dale's Corner
Looking great, I like the color combo.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-08-2017, 10:54 AM | #24 |
I got to see this truck in person last night and Curt is really doing it right. Quality parts and quality workmanship. Seeing it in person and then looking back thru the pics in the thread gives you a great perspective on the amount of work that goes into one of these trucks.
Doug
09-08-2017, 09:58 PM | #25 |
