Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 08-31-2017, 06:11 PM   #1
Majordixon
Ignition coil Problems
1965 Chev C-10, 283 V-8, was running fine. I noticed the coil was cracked around the neg. ternimal. So I replaced it, but I switch d the + and - wires on top of the coil. It would not start,. I realized my error, and connected them correctly, but the engine would not start. put the old coil back on, engine would not start, put new condenser on, still will not start. It will crank just fine. What did I burn up?
Majordixon is offline   Reply With Quote
Old 08-31-2017, 08:15 PM   #2
franken
Re: Ignition coil Problems
Use your trusty Ohmmeter to check the coil primary and secondary resistance. They should be low, but not zero, and certainly not infinite.
Check for spark.
Check voltage at the coil + side when the ignition is on and when cranking.
Make sure the points aren't welded closed, and are gapped right.
franken is offline   Reply With Quote
Old 08-31-2017, 11:17 PM   #3
Majordixon
Thanks I will check those.
