Old 09-11-2017, 10:55 PM   #1
Fawnzie
Fawnzie's Avatar
Torque specs and bolt sequence 250 Inline 6
Does anyone have the torque specs and the proper sequence of torquing the headbolts down? I cant find anything online. When I do there's 50 different answers. HELP!!!
Fawnzie is offline   Reply With Quote
Old 09-11-2017, 11:40 PM   #2
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: Torque specs and bolt sequence 250 Inline 6
Here's the sequence...it's the second one in the picture.
http://www.autozone.com/repairguides...00c152800849bb
Specs would be 90 foot pounds for all except the front two...those are at 80 so the front of the block doesn't crack.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-12-2017, 01:22 PM   #3
Fawnzie
Fawnzie's Avatar
Cool! Thanks for the info!
Old 09-12-2017, 04:30 PM   #4
GRX
GRX's Avatar
I usually go 95 ft-lbs on all but the front left (driver side) bolt, which is 85 ft-lbs. 90/80 is OK too. Follow the sequence shown in that image torquing in stages. All to 40 first, then 70, then to final. Re check torque after a few heat cycles.
Enjoy your 250 and welcome to the forums!
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 09-12-2017, 04:49 PM   #5
Fawnzie
Fawnzie's Avatar
Thank you. Been on for years, just changed my name
250 6, headbolt sequence, inline 6 chevy c10, torque specs
