09-14-2017, 09:31 AM | #1 |
Solid axle front axle 52 1/2 ton AD
Has anyone reversed the spring location from top to bottom of axle?
What are the pitfalls of this procedure, is it possible ..... SAFE
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
09-14-2017, 09:25 PM | #2 |
Re: Solid axle front axle 52 1/2 ton AD
ive never tried it but some thoughts come to mind:
with the spring under the axle you have no flat surface to mount the spring on which I think would cause the axle to be un stable. there may be some interference with the tie rod and the springs it may also put the axle below the scrub line between your wheels causing interference with the road. those are just some possible problems. there may be more. |
09-15-2017, 09:33 AM | #3 |
Considering a drop axle seems to be the norm, I'm guessing there are reasons not to go spring under.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
09-16-2017, 07:32 AM | #4 |
I did what you suggest here many years ago, and it did not come out well. I welded steel plates to the I-beam axle on the sides and bottom to make a pad for the springs, and used 4 large bolts to hold it down on each side. It was very low, and had very little up-travel, since the axle was so close to the frame. Also had bad bump steer due to the angles between pitman arm and spindle. I gave up on trying to make it work, and put it back the way it was. Later, put an IFS kit on it.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
09-16-2017, 09:22 AM | #5 |
Thanks for the input
I had a guy ask me this question as I had never heard of anyone doing this I will pass this on to him
09-16-2017, 09:27 AM | #6 |
I still think it is possible to make it work, if you want to mess with it long enough. But I would say a dropped I-beam axle or IFS would be a better choice if you have the money.
