Old 09-16-2017, 09:02 PM   #1
1low77c10
77 shortbed C10 bagged and bodydropped build
I have a 1977 C10 I am building, have finished a 5 inch z up front, and a 12.5 " notch in the rear. As of right now I'm curious what bags I'd like to run. Is anyone floating on the Slam Bag RE-8s? And if not, would these bags be okay for my application? They are 2600 lb, 200 psi bags. I am just curious as to will they hold my weigh? If not, what would be a good option? II plan to run a 6.0 with a t56 eventually and am not totally sure as to where I'll weigh in at when said and done. Im not looking to tow anything, only exception may be a street bike trailer, or a boat trailer but I've got other tow pigs at my disposal so if that doesn't need to happen then it won't. I'd appreciate all the input I can get, and I'm glad to get accommodated with some of you guys with the similar interests I have!
1low77c10 is offline   Reply With Quote
Old 09-16-2017, 09:07 PM   #2
1low77c10
Re: 77 shortbed C10 bagged and bodydropped build
Here's a sneak peak at where I am currently
Old 09-18-2017, 12:33 PM   #3
daddyjeep
daddyjeep's Avatar
I can't help with your questions, but I can welcome you to the group. It looks like you are off to a good start and at least have a plan. There are plenty of knowledgeable guys here that can answer your question.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
bagged, bodied, c10, shortbed
