Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-16-2017, 01:38 PM   #1
Old57
My 57 GMC on a 73 K20 chassis
I finally got some progress done on my truck. I got the cab mounted on the chassis, now its beginning to look like something. I'm planning on running tall skinny AT tires, something in the 255/85-16 range, so around 34". That should raise it up a couple inches from where it is now on the stands. It should fit under my 8' doors with this 4" K20 lift. The big block clears the firewall nicely too, so I'll probably use an HEI in place of the Mallory Unilite. I'll be changing to a short water pump, so that should allow for a clutch fan.
My 57 GMC build
Old57 is offline   Reply With Quote
Old 10-16-2017, 02:10 PM   #2
Old57
Re: My 57 GMC on a 73 K20 chassis
One more
My 57 GMC build
Old 10-17-2017, 05:34 PM   #3
DWilbur
Hello Old57
I love these old truck on 4X4 frame. I think they look cool. I had Unilite Dissy on my big block and it would burn out the center element in the cap at about 8000 miles. I would carry one behind the seat so I would not get stranded. Ended up going to HEI
DWilbur is offline   Reply With Quote
Old 10-17-2017, 09:58 PM   #4
Old57
Originally Posted by DWilbur View Post
Hello Old57
Thanks, I really like them set up 4wd. Can't wait to be able to drive it "one of these years". I was planning on using an HEI all along, but I started thinking ahead that I may have clearance problems, so I got this Unilite from craigslist. Now that I see that an HEI will work, I'll try to resell this Unilite and go with the original plan. HEI distributors are not anything nice to look at, but they sure are simple and work good.
My 57 GMC build
Old 10-31-2017, 09:01 PM   #5
Old57
I got the core support, inner fenders and driver fender mounted on for a mock-up. Starting to look like a beast.
My 57 GMC build
Old 11-08-2017, 02:19 PM   #6
61K10
61K10's Avatar
Looks good!! Nice shop also. looking forward to the rest of the build.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-08-2017, 06:22 PM   #7
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Awesome work! I love this body style and have been trying to find one around here to do what you're doing to it. Your chassis and engine look sweet too!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-08-2017, 08:57 PM   #8
Old57
Thanks guys! I got rid of the drum brakes on the 14 bolt and installed a Lugnut 4x4 disc brake kit.
My 57 GMC build
Old 11-08-2017, 11:28 PM   #9
Dieselwrencher
Very nice!
Ryan
Old 11-09-2017, 12:38 PM   #10
DWilbur
How are you setting up parking break. I installed disc break on the back of my transfer case.
Old 11-09-2017, 08:27 PM   #11
Old57
The transfer case parking brake is what I was thinking. I'll probably install a line lock in the brake system when I run all the lines for now, just to keep it from rolling when it's running in neutral. Do you have any pics or info on your transfer case brake? I've only seen a couple pics of them, nothing in person or in detail.
My 57 GMC build
Old 11-09-2017, 10:16 PM   #12
DWilbur
Picks of my T-case parking break
Old 11-10-2017, 07:38 PM   #13
Old57
That looks pretty nice! Where did you get it from?
My 57 GMC build
Old 11-25-2017, 08:53 PM   #14
RANDY COX
RANDY COX's Avatar
WOW I love the older 4x4 trucks, especially the 50's models they look just mean. That thing is gonna be Bad when it's done...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-25-2017, 09:26 PM   #15
jjzepplin
jjzepplin's Avatar
It's pretty bad right now! Love the parking brake!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-26-2017, 11:47 PM   #16
Old57
Thanks guys, I can't wait to be able to drive it. Also, the parking brake is on DWilber's truck, I was just asking him about it.
My 57 GMC build
Old 11-26-2017, 11:55 PM   #17
DWilbur
Advanced adapters is where I got mine from. they have 2 yoke size options.
Old 11-27-2017, 10:44 PM   #18
Old57
Thanks, I'll check it out
My 57 GMC build
Old 11-27-2017, 11:55 PM   #19
DWilbur
Parts Mike is who Advanced Adpters is they get the parking break from.
Old 03-01-2018, 11:43 PM   #20
Old57
I got the tires today, and had them mounted on my wheels. I finally have it sitting on its own again. The tires are Mastercraft CXT 255/85-r16, load range E, which is a 33x10. It has the stance I was looking for. I think it looks really tough. I need to get the hub caps repainted and then the wheels will be done. Hopefully I can get the front clip and doors pulled back off soon to get blasted and primed.
My 57 GMC build
Old 03-02-2018, 05:42 PM   #21
Dieselwrencher
Those look great!
Ryan
Old 03-03-2018, 10:19 AM   #22
68panelman
68panelman's Avatar
Does indeed, gonna be one tough looking truck, shoot,..it already does
68panelman is offline   Reply With Quote
Old 03-03-2018, 11:27 PM   #23
Old57
Thanks guys, I'm really happy with how it sits
My 57 GMC build
Old 06-16-2018, 09:21 AM   #24
Country705
Country705's Avatar
SWEET BUILD!!!!!! Any updates?
And in the end, it’s not the years in your life that count. It’s the life in your years.” — Abraham Lincoln
Country705 is offline   Reply With Quote
Old 06-16-2018, 08:10 PM   #25
Old57
Yes, I try to keep the build thread up to date. Click the link in my signature. I have all of the front sheet metal off and blasted/primed, clutch and brake pedals and master cylinders installed, tank mounted, heater/defroster and windshield wipers installed, exhaust made, etc. I hope to be running brake lines and fuel lines soon.
My 57 GMC build
