5 channel amp suggestions
Its been a while since dabbling in the car audio department and it seems there are a lot of compact options of 5 channel amps these days. I like the idea of having a small footprint that will power everything. Any suggestions or experiences for an amp?
Pieces I have for the puzzle: JL C2-650 component set for the front (60w RMS) JL C2-650x coaxial set in the rear (60w RMS) JL TW1 (75-300w RMS) The Alpine MRV-V500 (40wx4 + 150wx1) for $225 on amazon seems like a good choice or will that be underpowered?
My 1950 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=720858 |
Re: 5 channel amp suggestions
Most true audiophiles will not recommend a single 5 channel amp. However, I'm an old guy who likes my old music, and I do not want overwhelming bass which seems to be the preferred way to listen to music today. I like nice tight bass, and actually prefer 2-way speakers on top of that.
I got a NVX 900.5 from Sonic Electronic (online). I'm running a 12 inch Pioneer shallow mount in a custom box where the gas tank used to set, and 4-6 1/2 inch Kicker 2-way speakers in kick panel and custom mounts in the rear cab corners, up pretty high. I like the sound. The NVX 900.5 puts out 100 watts x 4 @ 2ohms, and 70 x 4 @ 4 ohms. The single sub is like 400 or so @ 2 ohms, and about 240 @ 4 ohms. That is adequate for me. Sound is nice and clear at any volume I care to listen to it. My head unit is a Retrosound. I forget the model, but it's the one with the USB input for my phone, which I use as a source. FM reception isn't the best I've ever had, but again, adequate for my needs. I would recommend the NVX 900.5. Compact, well made, easy to install. I used RCA's for inputs on all 4 channels. I like it very much. Oh, and I paid $209 from Sonic Electronic. NVX has a lower power option as well.... Thanks, |
![]() Join Date: Nov 2013
In my Blazer, I have the Pioneer GM-D9605.....currently using JBL 3-way 6x9 in the side panels and 5¼ round in the doors with a low profile 10" sub under the rear seat..
I wired the speakers in parallel and bridged them to get max power and cut to 2 ohm resistance (which is OK for that amp) wired the sub as normal....it sounds good and clean with adjustable sub....I'm happy with it.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#4 | |
The NVX gets recommended A LOT on diymobileaudio forum. A solid choice.
Personally, I would skip the rear coax. Run the front components separately on the 4 channels with a digital signal processor (DSP). |
driving is in my blood
I ran kicker 6.5"/1" components, rear 4x6 plates and a 12" sub via a kicker 5 channel amp for many years, it was a fantastic setup. So awesome it was stolen. Anyways- that kicker amp just pushed and pushed. Pushed more RMS via the sub channel then my sub could even handle. Miss that setup.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
