Old 11-04-2017, 10:18 AM   #1
Trackman101
Trackman101's Avatar
BBC Turbo 400 to LT4 T56
I have sold the complete driveline from my 71. Radiator to rearend , pan to carb ....gone. It will help cover a small portion of the cost of the conversion. I may regret that decision one day.
....There is no turning back.
Trackman101 is offline   Reply With Quote
Old 11-04-2017, 05:35 PM   #2
Trackman101
Re: BBC Turbo 400 to LT4 T56
The victim.
Old 11-04-2017, 10:27 PM   #3
Trackman101
Made a little headway. Got the trans, seat, carpet and steering wheel out too.
Old 11-06-2017, 04:34 PM   #4
Trackman101
After a couple tries I got the motor sitting in place and harness laid in. I built a pair of custom motor mount brackets to get it sitting where I want. Good news is I can use the factory oil pan. Bad news the oil cooler hits the crossmember so it has to go. I couldn't find anyone building a remote oil cooler set up for this oil pan yet so I cut the stock one apart and added some fittings to remote mount something later.
Old 11-07-2017, 02:03 AM   #5
Trackman101
.....Feels like I am talking to myself.
I've got a factory high hump so I am lucky there. Time to molest it .
Yaaa !, the wiring harness is long enough, I can hide the phone book ECM under the seat! Just need to figure out a grommet set up for the harness to come through the floor
Old 11-07-2017, 02:17 AM   #6
Trackman101
Took a knife to the harness. One wrong move and it can spell disaster.The GM tape that holds it together is high quality! Changed up the corrugated covering to a smaller weaved cover and was able to hide some of the wiring
Old 11-07-2017, 02:22 AM   #7
Trackman101
Needed a way to plug the water pump outlet for the oil cooler so I took the OEM fitting and welded a flange on to it so I could add a add a temp sensor. It's super tight. I just managed to fit it then there.
Old 11-07-2017, 02:25 AM   #8
Trackman101
Hopefully the Dakota dash will connect seamlessly to the ecm and save me a few wiring headaches.
Old 11-07-2017, 08:04 AM   #9
n2billet
Village Idiot....
n2billet's Avatar
Very Nice truck and extremely clean build!
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 11-07-2017, 08:43 AM   #10
Orange67
Orange67's Avatar
I'm in for this build. Very cool.
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 11-07-2017, 09:43 AM   #11
aboesec10
aboesec10's Avatar
if you've got the bim module from dakota, its a super easy install. Instead of using the plug in from the obd2 connector i purchased the same style connector from radio shack and hard wired them from the back of the obd2 to the bim module. Much cleaner look. 1 thing to note though is that you must unplug the gauges when using hp tuners. It won't load up as it recognizes the split in signal. Took me awhile to figure that one out....
c10clubtexas
aboesec10 is offline   Reply With Quote
Old 11-07-2017, 07:25 PM   #12
Trackman101
I do have the BIM module. Good tips . Thanks.
Drive Junkie supplied the front serpentine set up. The fit and finish is awesome. I went with it because I prefer the blower to have its' own belt. I am scratching my head how to connect the 2 wire ALT feed that Gm supplies in the engine harness. The alternator supplied by Drive Junkie is a one wire set up.
Old 11-08-2017, 09:28 PM   #13
Trackman101
Nothing exciting today. I extended the fuel pump and fuel pressure wires and got them run to the back along with my taillight harness. Modified my trans crossmember to match the new location of the mount for the T56 magnum. Set the new rad in to get a feel for how much room I 'll have for the shroud,fans and air intake.
Old 11-10-2017, 11:32 AM   #14
Trackman101
Not much to report. Moved my trans mount and got it bolted back in. It ended up moving forward a couple inches in relation to the old T400 location.
Gm warns that the LT4 doesn't create much vacuum so I have been messing with a hydroboost from a 03 Mustang trying to determine if I can make it work in the truck.
Old 11-10-2017, 02:14 PM   #15
Low Elco
Astro Van ones work well, PM LS1nova71 Eric is a bottomless pit of info.
Low Elco is offline   Reply With Quote
Old 11-10-2017, 04:37 PM   #16
Jason7121
Jason7121's Avatar
Cpp makes a real nice hydroboost kit called street beast I have it on my 71 with ls swap.
Jason7121 is offline   Reply With Quote
Old 11-10-2017, 04:43 PM   #17
Jason7121
Jason7121's Avatar
Hydroboost from cpp
Old 11-10-2017, 09:34 PM   #18
Pinky6872
Thats going to be one wild ride!
My Dropmember Equipped Build
Instagram @chrispinkosky
Pinky6872 is offline   Reply With Quote
Old 11-11-2017, 03:24 AM   #19
Trackman101
This badboy arrived today.
Wavetrac with 3.50 gears and 35 spline
Old 11-11-2017, 11:48 AM   #20
Jason7121
Jason7121's Avatar
Nice that should hold up to the 650 hp !
Old 11-11-2017, 08:00 PM   #21
Trackman101
Out with the old and in with the new. No drama. I like when that happens.
Old 11-11-2017, 08:48 PM   #22
builtbyKane
builtbyKane's Avatar
That's some great quality parts going into a slick truck.
builtbyKane is offline   Reply With Quote
Old 11-22-2017, 11:03 PM   #23
Trackman101
I unboxed and bolted up the headers. We got them from Ultimate. They were designed for a 67-69 Camaro LT4 swap. They work pretty well. I had to massage the passengerside engine pedestal a little bit but other than that easy peasy. Tons of room to slide them in.
The collector does hang about 1/2 inch below the frame but I can live with that.
Old 11-23-2017, 09:52 PM   #24
Trackman101
Got the 03 Mustang hydroboost adapter plate made.
....hope it works.Just need to build the linkage.
Old 11-25-2017, 07:57 PM   #25
Trackman101
Mounted up the new condenser. Now time to figure out the heat exchanger mount for the supercharger.
