11-06-2017, 01:06 PM | #1 |
radiator coolant overflow container placement
I see pics of engines bays with clean looking overflow jugs for coolant tucked in high on the inner fender.
I ordered a coolant overflow jug from LMC. got this massive square jug with a metal basket cage looking thing.....where the heck would that fit? I see some nice applications on this site. Where do you guys get your coolant jugs and brackets? Thanks |
11-06-2017, 03:14 PM | #2 |
Re: radiator coolant overflow container placement
I am pleased with this aftermarket overflow container
It is a Dorman 603-001 Coolant Reservoir Bottle, with a Dorman HELP! 82590 Coolant Cap added separately. Two holes drilled in the support frame on the radiator support (Right side top, and the middle bottom hole), and one standoff block of about 1" or so for the left top hole, with a bolt and nut going through the standoff and the radiator support there.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
11-06-2017, 03:45 PM | #3 |
Thank you
That looks perfect ! have located it on Amazon, |
11-17-2017, 11:55 PM | #4 |
Here's mine. This is a 69 Camaro windshield washer jug and bracket.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
11-18-2017, 07:34 AM | #5 |
Old member
Mine is out of a later 90's model GM product.
11-18-2017, 10:56 PM | #6 |
I used a '72 windshield washer container and bracket that I bought right here on the parts board. It looks exactly like the washer container I already had because it is! I mounted it on the vertical riser on the core support. It's in the background on the pic...
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
11-18-2017, 11:07 PM | #7 |
70+ ( Old Skool Club )
Subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-18-2017, 11:16 PM | #8 |
Don't have pics in the computer but I also used a w/s washer jug and bracket for an overflow. Mounted it on the right side fender just aft of the battery. Could not put it on the left side because that area holds a later model plastic "Tool Box" from the 95-2000 style trucks. That comes in VERY handy for oil check rag, spare fan belt, qt. of oil, couple wrenches.
Be advised if you add a overflow jug be sure you change your radiator cap to the recovery / closed system style cap. Normal cap will not allow the radiator fluid to flow back and forth. Without the closed cap it will just be a catch/puke bottle.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
