11-17-2017, 05:46 PM | #1 |
Differential bad?
I drove my 72 K1500 this morning and noticed a pulsing howl as I accelerated, once I was at speed it seemed to stop. On my way home going down hill I felt a sudden jerk like something momentarily bound up. I pulled over to check things out but could find nothing wrong. I drove about four more miles home and noticed the howling at lower speeds and as I decelerated. Could I have lost a tooth on one of the gears in the rear differential? I’m not feeling any vibrations or hearing any clunking sounds, just the howling sound. I don’t have time today so I’m going to pull the cover off tomorrow but thought I’d ask you guys if i should look elsewhere if I don’t find anything in the rear end.
Posted via Mobile Device |
11-17-2017, 07:17 PM | #2 |
Re: Differential bad?
Well I couldn’t wait, pulled the diff cover and found a broken tooth on ring gear. Couldn’t see any other damage so I cleaned in out, replaced the cover, filled it back up and went for a test drive. The howling is gone and is smooth. The closest rear end rebuilder is about 80 miles away, wonder if I could drive it that far?
http://smg.photobucket.com/albums/v655/aaronhero/ |
11-17-2017, 11:15 PM | #3 |
I wouldn't try it. You could distruck the whole thing. If you can pull it yourself & take it in another truck it would be better. Sometimes it is cheaper to buy a used one & install it yourself.
George |
11-18-2017, 09:20 PM | #4 | |
Thanks!
11-19-2017, 01:09 AM | #5 |
I’d flat deck it there
11-19-2017, 03:02 AM | #6 |
What tooth and where was it broken?
11-19-2017, 08:19 AM | #7 |
11-19-2017, 08:19 AM | #8 |
11-21-2017, 09:27 AM | #9 |
Have you thought about rebuilding it yourself? They aren't that hard once you know the steps and measurements. Not sure what tools you have as there are a couple specialty tools you would need, but the difference in cost between doing it yourself or someone else doing it, would be covered in that difference.
There are a lot of guys on this forum that can walk you through what it takes. The main thing you will need is patience in setting the measurements correct. For the first time, you would need to budget a full weekend and at least a 12 pack... Just an idea... Not everyone is comfortable doing a rear end or trans rebuild. Mostly it is due to being nervous in doing something new. But as for being nervous, it will increase the focus to do it right.
72 Chevy C10 383/465 69 Corvette convertible 454/650 |
11-21-2017, 12:19 PM | #10 |
Man, if you were in so cal, I gotta guy that would make a house call and do it right.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
