Old 11-20-2017, 04:41 PM   #1
'70_402
'70_402's Avatar
Heavy gauge battery cables.
Has anyone ever made their own cables from 1/0 or some heavier than factory cable?? My truck didn't come with any cables and i didn't know if any vendors made a non-factory top post style cable set? I'm going with an LS swap and i want to make sure i have a good supply of juice for all the goodies i'll be running.
'70_402 is offline   Reply With Quote
Old 11-20-2017, 04:46 PM   #2
cooperhw
cooperhw's Avatar
Re: Heavy gauge battery cables.
Yes. I always make my own. I go to the welding supply company and buy wire and put the ends on. Most of them have a machine that crimps the end on. I usually crimp one end on when I buy it, take it home and route it where it will live, then mark the exact length, take it back and crimp the second end.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 11-20-2017, 05:33 PM   #3
MARKDTN
Might also try a place that sells HD truck parts. Most of your 18 wheelers use 00 cable. Some can build to length as well.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 11-20-2017, 10:24 PM   #4
HO455
Post Whore
HO455's Avatar
Yes! It is a great idea. Here is a link with some info on the subject. There's lots of others on sizing and routing. Just do some searches.
http://67-72chevytrucks.com/vboard/s...d.php?t=747881
RIP Bob Parks.
Old 11-21-2017, 05:41 AM   #5
In The Ten Ring
After some resistance, I made my own battery cables. It was very easy.
I bought #2 gauge cable (red and black in color) from a NAPA store, using the old pieces as a length guide. Mine turned out overly long, I'll trim those back and recrimp.
I bought the end pieces at NAPA also. My father has a crimper, the thing is huge, lots of leverage, that he bought back in the 1960's when he was an electrician in a coal mine. Personally, I would use something like that if I were you, but the impact crimpers are much cheaper (the tool dad has would cost several hundred dollars today).
I found red and black heat shrink, glue lined, on ebay.com. That stuff is the bomb! The glue lining melts around the cable as it shrinks and conforms.....it permanently seals moisture out.
I used a carpenter's knife to trim back the insulation.
NAPA and I estimated what gauge to use based on how thick the wire cable looked on the old ones. #2 is much thicker than recommended, which should allow even more electrons to flow.
I went with new battery terminals, let me find what I went with. I like the terminals and the process so much, I want to do it to my daily driver Honda next summer to make the yearly cleaning of cable ends and battery terminals much easier.
https://www.oreillyauto.com/detail/s.../08805/4742296
Just search youtube for crimping videos, here are two good ones but I didn't have any fraying issues.
https://www.youtube.com/watch?v=DlqUFPGU6C4
https://www.youtube.com/watch?v=mBSnfHhi5xA
I used a heat gun to shrink down the heat shrink, I locked the newly crimped cable in a bench vise and then used a heat gun I bought to remove old vinyl floor tiles some years ago. It worked very, very well. No need to buy or use a torch of any kind. I did a practice run on some rebar my dad had laying around.
One thing I would do differently. Crimp on and seal one end, then mount that to your starter or engine ground (depending on which wire you are doing first). Then run that to your battery, allowing the cable to align itself how it wishes as it will twist to its most comfortable position. Then mark how the cable end will go. Then remove insulation, put on heat shrink, crimp end, and shrink heat shrink.
If you do not, the terminal end will likely be turned a way different than how it wants to lay and you'll have to fight that when you put the cable end onto the battery terminal. I'll be able to fix that when I trim my cables down. Somehow my new cables are about 6 inches longer than they need to be.
Be sure to clean your mounting points on starter and ground very well with a wire wheel (Dremel Tool) or brush and then use some dielectric grease to stave off corrosion.
A crimping tools I would have bought if I dad didn't have that big crimper.
https://www.amazon.com/PENSON-CAYQK0...+crimping+tool
https://www.summitracing.com/parts/l...SABEgK67fD_BwE
In The Ten Ring is offline   Reply With Quote
Old 11-21-2017, 07:23 AM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: Heavy gauge battery cables.
I haven't used them for my truck but I have used them for a few golf carts. I have a 6ft set going on the ramp truck for the winch if I ever get around to do it.
#2 AWG
3ft.
https://www.harborfreight.com/3-ft-i...awg-63748.html
6ft.
https://www.harborfreight.com/6-ft-i...awg-63747.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-21-2017, 10:45 AM   #7
specialtyretail
So,, what else you got???
specialtyretail's Avatar
I make lots of custom battery cables at the real job. They are kind of pricey, but they are just what the customer wants/needs for their particular applications.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks....
Sorry, we CANNOT ship larger parts. Thanks.
specialtyretail is offline   Reply With Quote
Old 11-21-2017, 12:17 PM   #8
demian5
demian5's Avatar
If you are redoing them, always a good idea to add one extra heavy gauge between the motor and frame.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-21-2017, 12:27 PM   #9
Greg58
Greg58's Avatar
Good point, you can never have too much grounding! I learned that when I used to build Demo Derby cars, those flimsy braided ground wires would pull loose, and then your engine would barely run.
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline   Reply With Quote
Old 11-21-2017, 12:41 PM   #10
bs46488
Just remember that not all cable is created equal.
I got a killer deal on some heavy gauge wire. I ran into sporadic cranking issues. One day I was trying to figure out what the issue was and brushed against the wire and practically got burned by how hot it was.
I ended up going down to my local welding shop and bought some welding cable and lugs. After redoing the cables it fires like a champ every single time.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
