Old 03-30-2002, 02:41 PM   #1
nosto
Flamin' Bass
nosto's Avatar
Post Rocker replacement - HELP!
Folks,
I'm starting to install the new floor pan pieces and something's got me stumped.
The PO had chopped the outside 2" off the floor pan so I don't have too much to go on. The "Chevy Assembly Manual" does have a few drawings, but nothing calling out this area in detail.
All the PO had at the bottom of the door is an outer rocker (still in good shape) and a flat inner rocker that was brazed to the outer at the bottom. There was about a 1/2" space left at the top of the outer rocker where the inner didn't meet it (don't know why.)
I drew this crude diagram and have the question: If the new floor pan reaches and is welded to the bottom of the outer rocker, WHERE DOES THE INNER ROCKER PIECE GO?
It seems like overkill to have both floor pan and inner rocker in place, to me.
Any hints would help here!
Thanks,
Rick
Absecon, NJ
1972 Triumph TR6 - full resto finally done!
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, headers, Flowmasters, Edelbrock, 600 Holley, 3/4 drop - in a million pieces
See some pieces at:
www.freephoto-i.net
username nosto53
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 03-30-2002, 05:56 PM   #2
ebfabman
Post
The inner rocker is the flat piece between your spot weld arrows. The floor replacement panel will have the inner rocker on it, or you can get just the inner rocker by itself.
ebfabman is offline   Reply With Quote
Old 03-31-2002, 12:39 AM   #3
hobby67stepside
Post
Maybe some of the aftermarket panels would work this way, but the ones I got from Goodmark would have been a nightmare. Mine were, but after hours of thinking and figuring I got things to work and I added an extra piece of steel in too. I want the rust to have to work harder and longer to ruin my work.
  • '05 2500 HD Silverado 6.0 liter
    '97 2500 4X4 454 eng
    '92 2500 4X4 350 eng
    '78 K20 4X4 400 eng
    '70 Boss 302 (owner for 27 years)
    '57 Ford shortbox 383 stroker TH350 tranny
    '23 T-bucket (built in '78)
    '02 Explorer
    '67 C-10 short step
NW Iowa
hobby67stepside is offline   Reply With Quote
