Old 11-25-2017, 07:43 PM   #1
blenon
69 c10 hood pops open
Recently my hood will pop open when hitting a small bump. It only pops loose and is still latched but not fully closed. I don't see any adjustments on it. Any suggestions?
blenon is offline   Reply With Quote
Old 11-25-2017, 07:47 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 69 c10 hood pops open
The hood pin in the center. Tighten it up and take the rubber stoppers on each side on the core support and run them in to take the pressure off the hood.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-27-2017, 10:22 PM   #3
blenon
Thanks for the help! I will give that a try this weekend.
Much appreciated
Old 11-28-2017, 06:53 AM   #4
Andy4639
Old member
Andy4639's Avatar
Much appreciated
No problem, let us know how it work out.
You may not need to do anything but screw the 2 bumper's in to let the hood sit all the way down also. I would try that first.
69 c10, hood, latch
