Old 11-26-2017, 01:46 AM   #1
hoyfkd
Advice please: Door dented on the end and not hitting dome light switch
I got my grandfather's old 72' Chevy pickup and it has a ton of issues. He used it for everything from logging to hauling crap off the mountain. It was rarely used, but kept running, for decades. Lots of rust issues, and tons of body damage everywhere... but it runs.
I am trying to figure out two issues right now, and how best to deal with them.
1) The dome light switch in the door jam was bad, so I got it working again. Unfortunately, I discovered that the reason he never bothered is because the door is smashed in at the front end (only on the jam-side, you can't see it from the outside) and so it never makes contact with the switch. I have double sided taped a chunk of wood to the door as a stop-gap, but I would like a more permanent solution. How big a task is banging out the end of a door? Is it feasible?
2) The hood is HARD to get opened. All of the parts of the latch are there, the springs are there as well. It releases just fine, but it doesn't pop up. I have to throw all my weight into it and work my finger in to get it started. Once it is started, it opens easy as pie. Is it supposed to pop up a bit?
Thanks!
hoyfkd is offline   Reply With Quote
Old 11-26-2017, 02:15 AM   #2
Curtb1971
Curtb1971's Avatar
Re: Advice please: Door dented on the end and not hitting dome light switch
Hey there, welcome the the site. First thing first, upload some pics of your truck when you get a chance. As far as the hood you might try oiling every pivot point on your hinges, grease the moving parts on the latch and where the striker/pin goes into the latch. The pin may need some adjustment the line up better after the bump's and bruises you described this rig may have. While you have the oil out you might what to lube your door hinges too. Hope this helps
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 11-26-2017, 07:26 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Advice please: Door dented on the end and not hitting dome light switch
On the door problem take the inside door panel off roll the window all the way up and cut a 2x4 to go inside the door that you can either hit with a hammer are barrow a friends hydrolic power pac and push it out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
body, door, hood
