Old 01-07-2018, 12:17 AM   #1
Duncan K
66 GMC Long to Short LS Swap
I've been lurking for a while, thought i should start a build thread before i start asking 100's of questions. This is my first build of any kind so I am figuring everything out as i go. This board has already been a world of help. I picked up a 66 GMC 910 LWB fleet side with a non running V8 with 4 on the floor It had been sitting in a farmers field for the last 20 years.
Plans for the build are a 5.5/7 static drop, disks up front and possibly rear, power steering, 6.0 LS/4L80E swap, rear mount gas tank and chopping it down to a SWB. Cab floors, rockers, supports and fire wall all need major rust repair.
This is how it sat for 20 years
[IMG]1 by Duncan Keith, on Flickr[/IMG]
[IMG]2 by Duncan Keith, on Flickr[/IMG]
[IMG]3 by Duncan Keith, on Flickr[/IMG]
Duncan K is offline   Reply With Quote
Old 01-07-2018, 12:34 AM   #2
Duncan K
Re: 66 GMC Long to Short LS Swap
Trailered the truck home and started to tear it down. Front sheet metal is in rough shape. Ended up cutting the front fenders to get them off, they were too far gone to bother saving. Grill support and rad support are pretty rusted out as well. Pulled the cab and built a quick roller stand for it. Pulled the old motor and trans as well.
[IMG]4 by Duncan Keith, on Flickr[/IMG]
[IMG]5 by Duncan Keith, on Flickr[/IMG]
[IMG]6 by Duncan Keith, on Flickr[/IMG]
[IMG]15 by Duncan Keith, on Flickr[/IMG]
Old 01-07-2018, 12:48 AM   #3
Duncan K
Got to work on some rust repair on the cab. This thing is rough!! 20 years in that field was not kind to this truck. Cut out the old rocker, floor pan, cab corner and rear support. Fit the new rear portion of the floor pan and started welding it in.
[IMG]7 by Duncan Keith, on Flickr[/IMG]
[IMG]8 by Duncan Keith, on Flickr[/IMG]
[IMG]10 by Duncan Keith, on Flickr[/IMG]
[IMG]9 by Duncan Keith, on Flickr[/IMG]
[IMG]11 by Duncan Keith, on Flickr[/IMG]
[IMG]12 by Duncan Keith, on Flickr[/IMG]
[IMG]13 by Duncan Keith, on Flickr[/IMG]
Old 01-07-2018, 01:00 AM   #4
Duncan K
Switched gears for a bit and took advantage of an empty shop. Brought the donor truck in and got to work pulling the motor and transmission. Decided it would be easier to pull the cab before pulling the motor. I don't have an engine crane but there were plenty of excavators in the yard.
[IMG]16 by Duncan Keith, on Flickr[/IMG]
[IMG]17 by Duncan Keith, on Flickr[/IMG]
[IMG]18 by Duncan Keith, on Flickr[/IMG]
[IMG]19 by Duncan Keith, on Flickr[/IMG]
[IMG]20 by Duncan Keith, on Flickr[/IMG]
Old 01-07-2018, 01:41 AM   #5
Captainfab
60-66 Nut
Welcome to the forum
Yes it looks like you have your work cut out for you with sheet metal repair, but it will be a nice truck when your done. Are you going to install the engine and trans as if, or go thru them?
Nice shop you have there too!
Old 01-07-2018, 11:26 AM   #6
Duncan K
I will definitely be going through the motor. If budget allows it will be getting new heads, cam and intake.
Old 01-07-2018, 03:27 PM   #7
slimjim66
Cool build, I’m doing the same thing except mines a step side. I’ll follow along. Good luck
slimjim66 is offline   Reply With Quote
Old 01-09-2018, 11:37 PM   #8
Duncan K
Got a little time today to start back on the rust repair on the cab. This thing is like Swiss Cheese. Kinda overwhelming when i look at how many areas need repair.
Started working on the bottom of the rear pillar.
[IMG]IMG_3639 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3640 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3644 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3645 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3646 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3647 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3650 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3651 by Duncan Keith, on Flickr[/IMG]
Old 01-09-2018, 11:51 PM   #9
Duncan K
Moved up to the front next. Have to repair the floor support before the floor pan goes in.
[IMG]IMG_3636 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3637 by Duncan Keith, on Flickr[/IMG]
Didn't want to order and wait for a replacement piece so I am trying to fab up a small section to patch in. Cut a piece of 16 gauge and made the first bend on the brake. Cant really get the tight radius I wanted so I lightly scored the second one with a cut off wheel and bent it over in the vice. I'll weld a bead on the underside to strengthen it up
[IMG]IMG_3653 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3654 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3655 by Duncan Keith, on Flickr[/IMG]
I'll have to brace up the cab a bit tomorrow before i cut that support out.
Also found a great deal on a grill and rad support to replace my old rotted out ones
[IMG]IMG_3638 by Duncan Keith, on Flickr[/IMG]
Old 01-10-2018, 12:41 AM   #10
66C10LB
Wow, major effort Duncan! Glad to see you scored the rad support and grill. Following along..
66C10LB is offline   Reply With Quote
Old 01-10-2018, 10:30 AM   #11
Chad215
Wow- lots of sheet metal work. I'll be watching to see how it comes out. Looks great so far
'64 GMC in progress
http://67-72chevytrucks.com/vboard/s...d.php?t=484861
Chad215 is offline   Reply With Quote
Old 01-12-2018, 11:55 PM   #12
Duncan K
More sheet metal work the last few days. Finished patching in in the floor support[IMG]IMG_3657 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3659 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3662 by Duncan Keith, on Flickr[/IMG]
Next up was the rear cab support. The first one I ordered was way too big, no way to make it work. Tried a different supplier off eBay. Not much better, about an inch too long and the angle where it meets the floor pan wasn't even close.
Are all these reproduction pieces garbage or is there somewhere better to order from?
[IMG]IMG_3669 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3668 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3670 by Duncan Keith, on Flickr[/IMG]
Had to chop and weld this thing back together. Would almost be quicker to make one from scratch.
[IMG]IMG_3671 by Duncan Keith, on Flickr[/IMG]
Eventually got it fitted and welded in. With that done i started on the front part of the floor pan
[IMG]IMG_3664 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3663 by Duncan Keith, on Flickr[/IMG]
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Old 01-13-2018, 12:02 AM   #13
Duncan K
Kick panel and front cab support fitted and tacked in
[IMG]IMG_3673 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3675 by Duncan Keith, on Flickr[/IMG]
[IMG]IMG_3679 by Duncan Keith, on Flickr[/IMG]
66 GMC 910
Old 01-13-2018, 01:11 AM   #14
Captainfab
60-66 Nut
Most all the aftermarket patch panels are pretty much the same regardless of the sticker on them. However the Tri Plus/Key Parts, parts do seem to be the better of all of them.
Old 01-13-2018, 09:50 AM   #15
Bomp
Bomp's Avatar
Glad to see someone who's not afraid to cut.
My truck was a jig saw puzzle at times.
Nice work. Following along on this build.
Bomp is offline   Reply With Quote
Old 01-13-2018, 12:13 PM   #16
Duncan K
Feels like all I am doing is cutting, not much original metal left
[IMG]IMG_3665
66 GMC 910
Old 01-28-2018, 10:55 PM   #17
Duncan K
Got back to work on the truck this weekend. Separated the trans from the motor and got the motor on the stand.Labelled and removed the wiring harness
[IMG]
Decided to leave the rust repair alone for a bit and work on the frame. Started by removing all the old exhaust hangers. Cut off the brackets for the bump stops to make room for a notch.
Next up it was time to make this thing a SWB. Removed the rear cab mounts and the first bed mount. Marked out the 12" section to be removed with a radius in the corners. Made the cuts with a cut off wheel and a plasma cutter. Fit up wasn't as good as I'd like on the passenger side. Man I wish I had more clamps for this job!!
Welded it up and ground them smooth. I'll have to pick up some heavy flat bar and add some reinforcing plates on the inside.
Clipped 8" off the back and relocated the rear cab mounts
66 GMC 910
Old 02-04-2018, 11:55 PM   #18
Duncan K
Continued work on the frame this weekend. Removed two bent up cross members in the front and rear along with the trans cross member.
Had to fab up a new base for my engine stand, cheap bolt together one I bought wasn't cutting it. Got a smoking deal on an engine lift as well so I no longer have to use an excavator.
Stripped the motor down to get it ready for clean up and paint. Got my Speed Engineering motor mounts in, just waiting for the new headers to arrive so I can set the motor in and build the new trans cross member
66 GMC 910
Old 02-05-2018, 12:32 AM   #19
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Great start on a killer project. Nice shop and big boy toys also.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 02-05-2018, 12:44 AM   #20
mongocanfly
Post Whore
mongocanfly's Avatar
wow ...that's a lot of rust...glad to see your saving another old truck...you should save all those rusted pieces and then weldem all together when you get done and make a wall art outta that stuff...mini-x sure is like a bunch of extra hands...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-10-2018, 11:54 PM   #21
Duncan K
Been working on a pipe notch, used a section of 5" heavy wall pipe and some 1/4" flat bar. Plumbed a centre line up from the axle, marked out the pipe notch and cut it out with the plasma cutter. Made a cardboard template of the frame and cut a piece of flat bar to match it. Fit everything up and welded the pipe to the plate. Then I used clamps, a torch and hammer to shape the flat bar to the curve of the frame.
[IMG]
Still have to weld it in and box in the inside. Ill probably round off all the corners and drill a few holes to plug weld in the middle of the plate.
66 GMC 910
Old 02-11-2018, 02:39 AM   #22
Rusty63
Rusty63's Avatar
Love the work so far,your pile of rusty cut out body parts looked just like mine did,hard to believe how fast it piles up!
Rusty63 is offline   Reply With Quote
Old 02-11-2018, 09:00 AM   #23
Bennett68C10
Bennett68C10's Avatar
Very nice work!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-11-2018, 09:28 AM   #24
Jferrante
Jferrante's Avatar
great work! also working on a 6.0/4l60 excited to see your cleanup.
Jferrante is offline   Reply With Quote
Old 02-13-2018, 09:39 PM   #25
Notch1988
Notch1988's Avatar
Hopefully I'll get to see this in person sometime.
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
