01-29-2018, 03:58 PM | #1 |
Install thread- Holley EFI Sniper on '72 402 big block
Part 1 Video https://youtu.be/ZOTmKqEPsHo
Moving the truck into the shop Old vs New On the engine. Vacuum and throttle/trans cable connected. 3/4" hole drilled for O2 sensor. It's 10+ degrees above horizontal and near the collector. Derp. Included 2.5" exhaust clamps for O2 sensor mounting don't fit my 3" exhaust. I'll need to go buy some 3" clamps: Draining some coolant to install the new temp sensor Temp sensor install location. May need to relocate it as I've read the reading back there can be too low. To be continued!
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
01-29-2018, 04:09 PM | #2 |
Re: Install thread- Holley EFI Sniper on '72 402 big block
Am subscribed -- your dog may want another basketball.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
01-29-2018, 07:57 PM | #3 |
Watching with interest. Great truck by the way.
John 69 c20, 396, th400, dana60, ps, ac |
01-29-2018, 09:14 PM | #4 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
I'm in for the ride, been looking at this for my 84
01-29-2018, 09:24 PM | #5 |
You will really like the sniper.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
01-29-2018, 09:37 PM | #6 |
Subscribed. Planning on the same thing for my 396. Looking forward to see if the stock cleaner fits. BTW....do you know what brand those headers are?
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust) |
01-29-2018, 09:49 PM | #7 | |
Headers, here you go: https://www.summitracing.com/int/par...1hkr/overview/ They fit well.A little low at the collector but liveable. |
02-05-2018, 04:10 PM | #8 |
Got the fuel tank drained in to jerry cans.
Removed the mech fuel pump. Assembled the elec fuel pump and filters. Found a factory return line I intend to use. Need to get a fitting to step down from the 3/8" fuel hose to the 5/16" steel return line going into the fuel tank. I intend to keep the 2 3/8" hoses (green and red below) next to each other, along the frame rail before running them up the firewall above the transmission, around the distributor into the EFI unit. I'd use the factory hard lines along the frame except they terminate way at the front by the radiator, not where I want to start running the 3/8" hose. The headers will be approx 3" away from the fuel line at the nearest point. I suspect this is OK for temps, but I'll look into something to wrap parts of the fuel hose with to protect it from heat as an extra step: https://www.amazon.ca/Heatshield-Pro...70_&dpSrc=srch Here's the plan: High flow mech fuel pump vs electric fuel pump.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. Last edited by Ekliptix; 02-05-2018 at 04:35 PM. |
02-05-2018, 06:05 PM | #9 |
70+ ( Old Skool Club )
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-05-2018, 06:26 PM | #10 |
Interesting subscribed
02-05-2018, 08:09 PM | #11 |
Beautiful Truck!
Love my sniper in my '72 Blazer 350sbc, cold starts, warm starts, throttle response, reliability! You look like you are taking your time and going about it the right way. Not sure if the return line step down will cause a problem, seems like I read something on that once, you may want to research it a little. I ran new 3/8" lines for both of mine. You probably could remove your 5/16 dump on the fuel sending unit, drill and install a 3/8" if you had too. Here's a little unsolicited, hopefully welcome advice, might save you some time and frustration: 1. Be patient, use the Holley tech support, they were very helpful getting it set up. Let them help you, if you have a question, they have answer. I called twice before I ever started installing mine, and a few times after. 2. There's an idle table that is not listed in the install instructions that they will walk you through if you cant get your idle where you want it. 3. I always let the fuel pump cycle before I start it, warm or cold and it will bump off in a 1/2 sec every time. Restarts can stumble if you don't. (I'm using an in-tank pump so that may be a difference) 4. There's a common whistle on these in acceleration, which they will say is normal characteristic, (it's annoying, unless you like the sound of City bus turbo's). You can totally get rid of it by using the Canton part# 85-154 ($30 on amazon) 1/4" 4 hole Phenolic Carb spacer. I tried a 1/2" open spacer first and caused a big vacuum leak which led to more issues. I'm a big believer in the 1/4" Canton, its proven to work with this set up, and shouldn't cause any clearance issues, I found a lot of guys were using it to eliminate the whistle. 5. Tom Kise with Holley tech has an 11 part post that goes through the most commons issues and how to avoid them on the Holley Sniper EFI owners and tech Facebook group listed under files. Great info! I had a few issues to work through, some due to installation mistakes, but once I got it straightened out she's been great ever since. I even turned the learning off after a few weeks (Holley Tech recommendation) and unplugged my monitor and threw it in the console. I found myself obsessing over the monitor and wasn't crazy about the look of it, just like an original looking dash. This is just my experience, I learned a lot from guys that had already gone down this road, reading ton's of threads and facebook post, like I'm sure you are. You'll read a lot of bad stuff on the Sniper and Fitech efi's, but installed correctly they will do exactly what they are meant to do, improve reliability, throttle response, and gas mileage. But, if your engine was having problems and not running right to begin with, it might not run right with efi. If I can be of any help PM me anytime. |
02-05-2018, 08:16 PM | #12 |
Nice pictures and detail...It gets me thinking!
I thought I would be the only one to spot that!
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
02-05-2018, 10:06 PM | #13 |
laying low
It will be interesting to compare differences in how it runs, carb vs sniper. I'm sure you made baseline mileage and acceleration notes.
I had a dog once that loved to chew on my football. He finally unlaced it and popped the inner tube.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-08-2018, 07:29 PM | #14 | |
02-09-2018, 12:35 AM | #15 |
Subscribed
02-09-2018, 08:46 AM | #16 |
I would be careful using the factory 5/16 return. Don't the directions specifically say to run the return entirely in 3/8?
I installed the sniper on a 79 c-30, and i was going to do the same thing- use a sending unit with a return. its been awhile but swear I got the advice not to do that. I ended up using the bulkhead fitting holley supplies and drilled into my gas tank. if you were deadset on using the factory return line, I would take the factory metal line off completely and connect the rubber hose right to the sending unit. edit- PS what headers are you running? looking for some for my lowered big block Last edited by Tiger Joe; 02-09-2018 at 09:00 AM. |
02-09-2018, 01:19 PM | #17 |
I’m in for info on it. Good video and sweet truck. I think I’m gonna do my seats like you have in the houndstooth.
02-10-2018, 02:24 AM | #18 | |
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
02-10-2018, 07:48 AM | #19 |
One question, are you using a single or dual plane intake with the Sniper system?
02-11-2018, 03:54 PM | #20 | |
Headers are these. They fit will, had to grind a little off the flanges to mount to the heads. https://www.summitracing.com/int/par...1hkr/overview/
02-11-2018, 03:58 PM | #21 |
02-12-2018, 10:32 AM | #22 |
I can’t wait to install mine.. also the reason I haven’t ordered it yet..
02-20-2018, 07:55 PM | #23 |
I've used a FiTech TBI on my ZZ4 69 Camaro and really like it. The trick is to follow directions precisely and ground it well.
I went a different direction on my 72 and installed a F.I.R.S.T TPI system which now has 12k miles on it with out a hitch. This is not your fathers 89 Corvette motor. lol
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
02-24-2018, 08:54 PM | #24 |
Part 2: https://youtu.be/hIClWrLBrBA
Got the fuel system installed. Removed the mechanical pump and used the included plate to cover the hole. The original bolts were too long for the plate, so I had to find some shorter bolts. The electric fuel pump is mounted along the frame using some existing holes (lucky). I ordered some of these off amazon. And after a bunch of looking found this 3/8" to 1/4" step down to connect to the factory return steel line into the stock tank. From the EFI unit in the engine bay, the 3/8" rubber return hose goes down the firewall, along the frame, through 2 of the rubber retainer clamps, into the 3/8" to 1/4" step down fitting, into a new 1/4" rubber hose, into the factory 1/4" steel return hose which goes into the cab and tank. I heat tape wrapped some of the fuel line and post pump filter just as a precaution, and it looks cool. Also got the 3" exhaust clamps from amazon so O2 sensor is installed.
02-24-2018, 09:12 PM | #25 |
Nice work.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
