Window kit?
Could someone recommend a decent quality window kit for a '70 C30? I need to replace the mechanical working of the device that moves the side windows up and down. Mine will occasionally bind and they rattle inside the doors. I keep finding electric conversion kits and I don't really want that. Any recommendations?
Thank you. |
Re: Window kit?
Replaced the left side regulator in my 68 last weekend with a OER regulator from Classic industries. Window rolls up and down perfect now.
I just ordered a Goodmark right side regulator from Rock Auto for just over $30 shipped...I should have ordered it at the same time as the left, but after replacing the left one I figured might as well do it now since I haven't put the window felt kit on passenger side yet. I had to take off the new felt kit from the drivers side since I had installed it already. I would recommend changing everything you can in the door if you have to do the regulator, makes life so much easier. I am replacing the regulator, door handle relays, locks, plus installing new window felt and trim. HTH, good luck. |
Post Whore
![]() Join Date: Feb 2016
Re: Window kit?
I'm pretty sure my new regulators came from Classic Industries. Been happy with them so far. I also put new felts in the tracks and made sure the rollers and the channels they move in were clean and smooth. Then I lubed them with a dry lube (garage door track lube) to hopefully keep things smooth over the long term.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Re: Window kit?
Much thanks. I'll give Classic Ind a look. And I agree, everything in the door should be replaced, locks, handles, felt etc..just wanted to get everything in one order if possible. Thanks again.
