04-24-2018, 07:35 AM | #1 |
Headlight upgrade
Hello all,
I have found this site a wealth of knowledge over the past few years. I wanted to thank everyone for that. My predicament now is headlights. I have two with bulbs that need to be replaced so I decided now is a good time to upgrade. I would like to upgrade my original 1969 GMC C30 headlights to LED. They are the 4 5.75 bulbs. I have no idea where to start or the best bulbs for the job. Any and all information would be welcome!
A lot to think about, not much to worry about... |
04-24-2018, 07:44 AM | #2 |
Re: Headlight upgrade
So do you currently have the factory seal beams or have they already been converted to halogen?
68 C10 long-fleet, Long and low is the way to go. factory: 307 sbc, SM465 4-speed, 12 bolt 4.11 rear end. 75,000 original miles. Build:Ole Blue Millennial and can drive stick. "Too many people have opinions on things they know nothing about. And the more ignorant they are, the more opinions they have." -Thomas Hildern |
04-24-2018, 08:24 AM | #3 |
The Nokya sealed beam conversion kit and LASFIT 9005 HB3 9006 HB4 bulbs seems the way to go. The lights are $90 a pair on Amazon and the bulbs are $63 for all 4.
04-24-2018, 09:53 AM | #4 |
All sealed beam..still original.
04-24-2018, 09:59 AM | #5 |
Okay, so are you wanting a halogen conversion with LED headlight bulbs, or the fancy projectors or whatever with the LED halos? Just trying to clarify.
04-24-2018, 10:01 AM | #6 |
100% correct
04-24-2018, 10:05 AM | #7 |
Wait I think you misread my question. So, a factory looking housing with a LED bulb? OR something like this?:
04-24-2018, 10:30 AM | #8 |
I don't have a preference yet...looking for ideas. Would like plug and play but wouldn't be opposed upgrade of the whip as well
04-24-2018, 10:35 AM | #9 |
Oh okay. LMC has a pretty good selection of traditional lights and traditional looking with halos. These are pretty cool but pricey:
04-24-2018, 02:30 PM | #10 |
Old member
Before you do the lights do the relay upgrade this will insure you get the most out of your lights to begin with. A lot of people stop at this mod after seeing how bright they are.
I have been looking at a set for my 64 SS Impala as well but haven't found what I want yet.
04-24-2018, 02:35 PM | #11 | |
04-24-2018, 04:39 PM | #12 |
Old member
It depends on if you buy a kit are make your own. I made my own and wired them in. The relay takes the load off the truck wiring system. It improves the out put of your lights.
04-24-2018, 04:57 PM | #13 |
Please don't buy the "new" ultra bright ones ! Don 't know what kind they are but they are blinding for the oncoming traffic. I drive a tractor trailer rig at night and my colleagues and I all agree they should be illegal ! The shade of white is just very uncomfortable to the eye. I wouldn't want to be on a country road with those lights coming at me ! They absolutely blind you !
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
04-24-2018, 08:09 PM | #14 |
As I have never had a gmc. Do both bulbs act as hi/low or dose it just switch from inner to outer or vice versa?
AJC |
04-24-2018, 08:33 PM | #15 | |
20' Daredevil (Ret)
So on high beams, all four lamps are lit.
04-24-2018, 11:26 PM | #16 |
Who Changed This?
A slight diversion in the topic, but maybe it will help the OP. Does anyone have a before/after pic of the difference in headlight brightness with a relay kit? I suspect that a relay kit would also serve to brighten the tail and marker lights, since their voltage supply would be higher if the headlights were fed through a circuit directly from the battery, instead of all the power going through the headlight switch. I could just drop the $30 for the relay kit, but I would rather spend $30 worth of time on diagnosis, because I was so poor as a kid that the only thing I could pay was attention.
04-25-2018, 02:40 AM | #17 |
Customization is what you want it to look like -- not what other people think it should look like |
04-25-2018, 12:01 PM | #18 | |
Who Changed This?
04-25-2018, 12:13 PM | #19 |
Back in the sticks
I bought a set of the LMC bulbs like up above. I also bought their relay wiring harness in hopes of making them brighter. The wiring harness didn't last 2 months. Relays immediately gave up.
I already had some HID lamps installed, not the old style bulbs. Once I get the other issues worked out on the pickup I intend to install the new LMC bulbs and try to get the harness working again.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
04-25-2018, 01:35 PM | #20 | |
Old member
This is why I made my own harness and it works great. I've done my 71,67, 64 Impala and my 56 Bel Air + a few friends vehicles.
04-25-2018, 01:43 PM | #21 | |
Back in the sticks
Thanks, Jeff
04-25-2018, 02:22 PM | #22 |
There is a huge difference in cheap relays vs Bosch-Tyco relays. The longevity of the Bosch is amazing. I ordered some cheap relays for my cooling fan and air ride management, but the relays failed within a month. I paid extra for the Bosch brand and a year later, still going good. The relays in my Ford Expedition are all Bosch and I have never replaced one...bought new in 2000 and has 180,000 miles. That says something.
04-25-2018, 03:00 PM | #23 |
Old member
When I did mine LMC was having terrible reviews on theirs. The wires where backwards. Also as stated I used Bosch relays. Mine have been in the truck for several years now and no problems.
04-25-2018, 09:44 PM | #24 |
I just bought a pair of 7 in halogens from rockauto for 8.00 each
I BELIEVE IN JOHN 3:16 |
04-26-2018, 11:15 AM | #25 |
Back in the sticks
Thanks, when I reinstall, I'll upgrade to Bosch relays and check the wiring. That could have been the problem all along, I just don't drive it enough.
Tags |
headlights, lights, upgrade led |
