Old 06-09-2018, 11:02 PM   #1
wphilli1
wphilli1's Avatar
Removing Radiator Support Rods
Hi Guys,
Silly question time, but I was wondering if anyone has any experience removing the rods connecting to the radiator support behind the grill on a '58? I'm not sure what they're called. I am looking to add a pusher fan to supplement my mechanical one on very hot days or when stuck in traffic, and I need a few extra inches to fit the one I have on hand. Just wondering if its a terrible idea or not.
Thanks a lot,
Wylie
Thanks,
Wylie
'58 Apache 3100 4-Eyed Work Truck
wphilli1 is offline   Reply With Quote
Old 06-09-2018, 11:20 PM   #2
MARTINSR
MARTINSR's Avatar
Re: Removing Radiator Support Rods
Someone will get you the exact info as I don't have a 58, but a 48. But I believe they are the same and riveted on. You will have to grind off the head of the rivet and then knock the rivet out of the hole with a punch and hammer.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 06-09-2018, 11:41 PM   #3
Black_Sheep
Black_Sheep's Avatar
My '58 has not had that brace for 10+ years, no problem.
Black_Sheep is offline   Reply With Quote
Old 06-10-2018, 12:27 AM   #4
MARTINSR
MARTINSR's Avatar
And I never had them on my 48 since when I bought it in 74.
Brian
1948 Chevy pickup
Old 06-10-2018, 01:17 PM   #5
wphilli1
wphilli1's Avatar
Cool guys, I figured I'd be ok but its better to check before cutting I've learned. Haha. Time to get out the death wheel then!
Thanks,
Wylie
Old 06-10-2018, 03:37 PM   #6
mr48chev
mr48chev's Avatar
At worse case you will gain a few squeaks and rattles that you didn't have before. They do take some of the stress off the radiator or it does put a bit more on it when they are gone.
On the other hand we don't tend to drive our fixed up trucks over the rough roads and trails or fields that were the norm for them in their fist life. They may not be as necessary as the trucks probably don't get treated the way they did back then.
My ongoing truck projects:
Old 06-10-2018, 04:56 PM   #7
MARTINSR
MARTINSR's Avatar
Very true, the engineers didn't put them there because they had nothing to do that afternoon.
Brian
1948 Chevy pickup
Old 06-10-2018, 07:09 PM   #8
my56chevytruck
my56chevytruck's Avatar
Originally Posted by wphilli1 View Post
Hi Guys,
Thanks a lot,
Wylie
Sorry no 58 but I did remove the cross bracing rods to my 56. Do you have a puller fan setup?
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 06-11-2018, 11:55 AM   #9
mikebte
Good question. I was literally about to remove mine to install an A/C condenser and was unsure of my actions.
mikebte is offline   Reply With Quote
Old 06-12-2018, 04:28 PM   #10
_Ogre
_Ogre's Avatar
ok. i'll ask the obvious... do you have a shroud on your fan?
most fan shrouds are long gone by the umpteenth owner
fyi this is what a oem tf shroud looks like
not sure how a pusher will work with an oem puller
it may just block the air in the off position
rather than mess with the bracing holding the front end on
use a shroud or use an electric puller no oem fan
shop air compressor timer
Old 06-12-2018, 04:50 PM   #11
Speedbumpauto
Speedbumpauto's Avatar
"Very true, the engineers didn't put them there because they had nothing to do that afternoon."
That may be true, but it wouldn't be the first time something was added due to faulty science or changing science where we learn things we didn't know we didn't know.
Speedbumpauto is offline   Reply With Quote
Old 06-13-2018, 08:52 PM   #12
wphilli1
wphilli1's Avatar
Thanks again guys,
The truck doesn't overheat except n very hot days or if I'm idling for a long time. I bought the electric fan when I went to Fitech EFI so the efi could control the fan and to free up a little power the non-clutch mechanical fan was robbing, but it didn't end up fitting as it hit the water pump pulley by a quarter inch. Anywho, I just had the fan sitting around and thought I might put it to good use. It's already in as of last night and working fine, no extra squeaks I've noticed yet!
Thanks,
Wylie
