Old 06-12-2018, 11:05 PM   #1
Johns327
Johns327's Avatar
Vintage Air drain
I am installing a Vintage Air system in my 55 second series and was looking at the drain. Does anybody have a better way than just punching hole into fire wall? I went to get deal of work to clean my fire wall off and adding another line that just drips seems counterproductive. Been thinking of 3/8 line bent to follow the inside of the cab to the side vent and dropping the line in there. Bad idea? Other ideas? Pictures?
Johns327 is offline   Reply With Quote
Old 06-12-2018, 11:33 PM   #2
my56chevytruck
my56chevytruck's Avatar
Re: Vintage Air drain
you've got the right idea, thats where I'll be running my vent, but sorry no pics yet. I too spent a lot of time cleaning up my firewall and won't be cutting any holes in it, so you're dead on.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 06-12-2018, 11:38 PM   #3
oldman3
oldman3's Avatar
Johns327, I did about the same as you said. Bent up tubing that comes thru the cab. It drains down behind the front tire. Here's a pic, hope this helps...Jim
oldman3 is offline   Reply With Quote
Old 06-12-2018, 11:59 PM   #4
OrrieG
OrrieG's Avatar
I dumped mine into the wheel well thru the side cowl too.
OrrieG is offline   Reply With Quote
Old 06-13-2018, 02:24 PM   #5
_Ogre
_Ogre's Avatar
not the best pic, i did the same as orrieg, under the unit out thru the side into the fender
you can see the black line in the kick vent
my kick vents are cut out since i shaved the cowl vent
shop air compressor timer
Old 06-13-2018, 11:37 PM   #6
Johns327
Johns327's Avatar
Thanks all. I’m going to run mine out the vent as well.
