Old 06-13-2018, 12:25 PM   #1
c3888
Center Bore Diameter
I have a -70 shortbed stepside. Disk brakes in front. Drums rear.
Question 1: the wheels is lug centric (not hub centric)?
Question 2: does it matter how wide the center bore diameter on the rim is, given yes on question1, and have this Lug Nut Seat Style Conical seat - 60 degree?
Do not know what it is on mine, but let us say it is 78,3 mm. Will rims with 108 mm center bore diameter fit?
c3888 is offline   Reply With Quote
Old 06-13-2018, 12:48 PM   #2
raggedjim
raggedjim's Avatar
Re: Center Bore Diameter
The original wheels are hub centric, but you can use lug centric on your truck. Most aftermarket wheels are lug centric so they fit more applications.
Yes, a larger bore lug centric wheel will fit (backspacing is a different matter).
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 06-15-2018, 08:08 AM   #3
Mike C
Mike C's Avatar
Is your truck 6 lug disc or 5? If someone has converted the truck to 5 lug then both ends probably have the same pilot diameter for the wheel hub and you could get hubcentric wheels.
But if you are 6 lug still, the rear pilot will be significantly larger diameter than the front.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-15-2018, 09:36 AM   #4
c3888
6 lugs front and rear.
hub size, wheels
