Old 06-13-2018, 11:17 PM   #1
68blackbird
68blackbird's Avatar
Steering column mount?
Like to see/hear what you guys did to mount your column to firewall...Kel
Kel's 1950 GMC 1/2 ton build
68blackbird is offline   Reply With Quote
Old 06-14-2018, 12:07 AM   #2
mikebte
Re: Steering column mount?
I closed up the hole and used this on my tilt column, old mocked up right now. I'll post another once cleaned up and finished.
mikebte is offline   Reply With Quote
Old 06-14-2018, 02:58 AM   #3
MiraclePieCo
MiraclePieCo's Avatar
Cut an old rubber floor mat to make a seal.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 06-14-2018, 01:18 PM   #4
_Ogre
_Ogre's Avatar
what column? column manufacturer probably has a floor mount
shop air compressor timer
Old 06-14-2018, 01:47 PM   #5
68blackbird
GM tilt from Speedway. The only ones I saw there were for flush mount(mikebte). I suppose I could re-shape mine, just looking to see if someone had a better idea, Kel
Old 06-14-2018, 01:55 PM   #6
68blackbird
This is what I used at dash(SS), thinking might be best option on the bottom.
Old 06-15-2018, 03:55 PM   #7
_Ogre
_Ogre's Avatar
that's actually the floor mount
i think you need something a little heavier on the dash
i'd hate for the column to come off in your lap driving down the road
Old 06-15-2018, 05:01 PM   #8
68blackbird
That's what I thought at first, but after reading the Q & A on SW, went ahead and got it...
I have 56 Chevy 3200 truck. Could this mount be used as a "upper" mount to the dash as well as a lower mount to the floor, using part #91032978.
Product Owner - mainmotorco
John, we have used them as upper and lower mounts on a few of the trucks we have built.
I had bought this floor mount, after looking at it....again, it will work. I thought because it was a flush mount, it wouldn't work because my floor/firewall was not flat? I have it temporarily screwed down to finish the linkage. Small hole to fill now. Thanks for the input, Kel
Old 06-15-2018, 06:35 PM   #9
Black_Sheep
Black_Sheep's Avatar
I made an aluminum plate and bolted through the toe board.
Black_Sheep is offline   Reply With Quote
