06-25-2018, 05:07 PM | #1 |
25 gallon Fuel tank in a SWB?
Just putting together a rather large parts list for a build.
I'm looking to run a 6.0L truck motor and want a larger gas tank. Specifically I wanna run a 87-91 Suburban or Blazer 25 gallon tank part number gm15c or rtg9125 so I can drop in a AC Delco EP381 But the tank ooks to be 10" longer and I'm concerned it won't fit length wise between the QA1 rear end assembly (specifically the panhard bar) and the furthest rear crossmember. I do plan to raise the bed 7.5 inches so the hanging depth is not a concern. Just wondering if anyone has done this? |
06-25-2018, 09:40 PM | #2 |
Re: 25 gallon Fuel tank in a SWB?
I put one in my longbed, but I don't think it will work in a shorty. See LFD's "LowBuck" thread:
http://67-72chevytrucks.com/vboard/s...&postcount=346 |
06-25-2018, 11:03 PM | #3 |
That's what I fear.
At 15mpg the extra 6 gallons would be nice, not to mention it's nearly 1/4 of a Boyd tank |
06-26-2018, 09:52 PM | #4 |
This tank will fit in a shortbed frame. I have done it. Just remove the rear brace. I use the word brace loosely as it doesn’t effect the rigidity of the frame.
06-26-2018, 11:35 PM | #5 |
06-27-2018, 08:31 AM | #6 |
The rear brace where the tail lamp harness comes thru or the crooked one just aft of the axle?
I’m up for some pix too. EDIT; Here's his build thread, it's the rear x-member removed http://67-72chevytrucks.com/vboard/s...d.php?t=669899
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 06-27-2018 at 08:53 AM. |
06-27-2018, 09:12 AM | #7 |
The crooked one aft of the axle
06-27-2018, 12:27 PM | #8 |
Jesse, your build thread just shows the rear one pulled out. Did you remove the other one also?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-27-2018, 12:34 PM | #9 |
Just the rear.
06-27-2018, 01:05 PM | #10 |
To the OP, if the tank will fit, your plan will work great. I have the same tank and pump running my 5.3
06-27-2018, 02:57 PM | #11 |
09-17-2018, 05:56 PM | #12 |
Awesome thanks everyone. I have a long bed that is being cut down. I know 6" is supposed to be taken off the rear but I've seen where only 4" needs to be taken off the the bolt holes can be adjusted for the additional 2". That should leave plenty for the tank.
09-17-2018, 10:55 PM | #13 |
I thought it was 8” off the rear and 12 in the middle?
09-17-2018, 11:11 PM | #14 |
Jesse, I’d like to do the same thing but in your pic it shows a straight filler neck but all those part numbers come up with a curved one. Did you modify the neck?
Also, I think I’d need more fuel than the pump mentioned as I’m doing a turbo 6.0 ls. Wonder if a higher flow pump would fit in the basket? Would you happen to remember the basket assembly part number? |
09-17-2018, 11:14 PM | #15 |
09-17-2018, 11:33 PM | #16 |
Find this: http://67-72chevytrucks.com/vboard/s...d.php?t=622513
I’m sure a walbro 450 will support my expected 500-550 hp. |
09-19-2018, 06:46 PM | #17 |
Been searching like crazy for the last few days on the subject but can’t seem to find a pic of the finished install from behind. After reading I’m now concerned about how the tanks looks from behind; well, that and where the exhaust pipes would now exit the truck. Anyone have pics of this 87 tank finished up and a view from the rear?
09-19-2018, 06:52 PM | #18 |
It doesn't hang as low as the blazer 21 gal tank. So you should be ok. As for exhaust. You can dump before Axle or flip them over the frame
09-20-2018, 09:37 AM | #19 | |
09-20-2018, 09:39 AM | #20 | |
09-20-2018, 09:47 AM | #21 |
This was shortly after I put the exhaust on.
09-20-2018, 09:10 PM | #22 |
Thanks for that. This is exactly the route I’ll go. Looks great.
09-27-2018, 05:58 PM | #23 |
Can anyone let me know a part number for the sending unit/basket part number for this tank. If I simply search for 87 blazer tank it looks like there are a few different option. I’d like to get a basket I can install a walbro pump in to support 600 whp
12-28-2018, 10:10 PM | #24 |
I’m coating the frame this weekend and get to start mounting stuff back to the frame. Jesse; how did you mount the tank? Did you purchase straps? The only way I can see when dry fitting the tank is bolts through the tabs of the tank but that seems like a bad idea.
02-04-2019, 06:49 PM | #25 |
I thought I would post some pics in case someone digs up this post and is wondering the same way I was about fitment.
I still never got a good answer how others have mounted this. My best guess after dry fitting it, is to add some rubber pads in specific pressure points where the tabs meet the frame and then getting some sort of universal gas tank strap while also adding some rubber between strap and tank as well. |
