06-26-2018, 11:48 PM | #1 |
What did I blow up now
Took out the 71 this weekend and she was acting weird. Accelerate from 0-30 fine then sputtered from 30 to 38 then ran like it rear was on fire until 50 then did the same thing until 58 mph. When it was sputtering was blowing black smoke like a diesel. No problems going up and down the rpm band while in park.
Running a 350/350 combo and both were rebuilt 528 miles ago but long enough to have no warranty. Truck does sit a bunch but has never acted up before. |
06-27-2018, 02:05 AM | #2 |
Re: What did I blow up now
Timing chain intermittently slipping under load maybe?
1953 Kaiser Manhattan “Sled” 1968 C10 CST LWB 1991 Trans Am GTA “White Nasty” 2006 Dodge Charger RT Built TH400 for Sale |
06-27-2018, 02:37 AM | #3 |
Timing chain can't "slip" and then miraculously "retime" itself.. My money's on an ignition problem.. You say the truck sits a lot?? How old is the gas in the tank??
06-27-2018, 07:47 AM | #4 |
Gas is about 6 months old but has stabil in the tank
06-27-2018, 08:32 AM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
What's the initial timing? What carb? And some rebuild details like was a new cam and lifters installed and properly broken in? Pull the valve covers and check the rockers and springs...?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 06-27-2018 at 08:47 AM. |
06-27-2018, 08:40 AM | #6 |
HEI? Cheap HEI module in the HEI?
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
06-27-2018, 10:25 AM | #7 |
Running an Edelbrock 1405 carb. Engine was ran for the first 300 miles with break in oil then drained and the valves were adjusted and the oil was switched to Mobil 1. Details I remember from rebuild are few as the paperwork was lost last year when basement flooded. But running a mild can upgrade with cast votrec heads bored .60 over. Trans has a stage 2 shift kit and a 2200 stall. Builder said had to have an octane booster added with each tank as 92 octane would not cut it
06-27-2018, 10:26 AM | #8 |
06-27-2018, 10:29 AM | #9 |
Hi neighbor. The black smoke makes it seem like a carb problem. I'm thinking the choke is going off & taking a set. Some of those from that era had a spring around the choke pulloff. If the choke didn't heat up enough the spring would close it.
George |
06-27-2018, 11:08 AM | #10 |
1405 should be a manual choke. Is the choke all the way open?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
06-27-2018, 11:24 AM | #11 |
What is your timing set at? Get your timing set correctly first, then you can move on to the carb.
72 C10 lwb fleetside -stock 350/350 combo |
06-27-2018, 07:30 PM | #12 |
That's now the plan this weekend then follow up with the carb. Vehicle is at my in laws right now so has to wait a few days. Miss read the carb model(dang bad eyes) and it is the 1406 with the electric choke.
06-27-2018, 08:23 PM | #13 |
06-27-2018, 09:25 PM | #14 |
I had an HEI coil start to go bad on me and act the same way. Lots of backfiring though as the raw gas which made it into the exhaust pipes would get lit off when the coil cam back on. Ultimately traced it to one of the wires which plugs into the bottom of the distributor cap being loose.
- Just a dad helping his 16 year old build a '72 he bought himself |
06-27-2018, 09:49 PM | #15 | |||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-27-2018, 11:27 PM | #16 |
Dirty gas tank?
06-28-2018, 08:30 AM | #17 |
Change the fuel filter at the carb and check out the HEI cap, rotor and coil for problems. Make sure the ignition module has the proper heat sink goo on the bottom of it.
06-28-2018, 12:26 PM | #18 | |
06-28-2018, 01:24 PM | #19 | |
Edit... also what is your TOTAL timing? I think the Vortec heads require it to not be too high. |
06-28-2018, 02:55 PM | #20 |
Change the fuel filter.
06-28-2018, 04:53 PM | #21 |
Old gas, water in tank?
See it quite often at work |
06-28-2018, 08:26 PM | #22 | |||
Gary
06-29-2018, 03:18 AM | #23 |
Scrapper 1
Did you for get to put the distributor bolt in and tighten it down
06-29-2018, 08:15 AM | #24 |
Thanks for the help gives me a good place to start looks like next week I will start with:
1. Dump the gas tank(where to put 17 gallons of fuel that will be fun) 2. Replace fuel filter. 3. Go through hei and check wires ect. 4. Pull plugs and check probably just replace. 5. Check timing |
06-29-2018, 09:19 AM | #25 | |
