Old 06-27-2018, 07:36 PM   #1
mygmctruck1
Power Steering 68 gmc 4x4
I have the pump and the power steering box , what else do I need to change over from manual to PS on my 68 gmc 4x4
mygmctruck1 is offline   Reply With Quote
Old 06-29-2018, 11:03 AM   #2
cypressbog
Go Pack Go!
Re: Power Steering 68 gmc 4x4
You might want to get in touch with Mike (67-72chevytrucks). He’s in Marquette, MI and completes 100 point concours restorations on these trucks. He has a 1968 short fleet 4x4 50th anniversary truck. He’s been looking for the ram assist power steering components for a 4x4 for several years now.
cypressbog is offline   Reply With Quote
Old 06-29-2018, 11:37 AM   #3
mygmctruck1
[QUOTE=cypressbog;8291165]You might want to get in touch with Mike (67-72chevytrucks). He’s in Marquette, MI and completes 100 point concours restorations on these trucks. He has a 1968 short fleet 4x4 50th anniversary truck. He’s been looking for the ram assist power steering components for a 4x4 for several years now.[/QUOT
Thank you but I need more info to get ahold of him
Old 06-29-2018, 02:58 PM   #4
Mts67C10K20
Mts67C10K20's Avatar
Welcome to the board
And in Michigan too not to far from dowagiac
Things you my need
Pittman arm
Mounting bracket
Hoses
And not sure if the tierod is the same for manual and power
Have fun
Mts67C10K20 is offline   Reply With Quote
Old 06-29-2018, 03:09 PM   #5
liftlawssuck
liftlawssuck's Avatar
This is a piece of cake to do. Steering box (4wd only), steering pump, brackets for steering pump, pulleys for steering pump. hoses between box and pump, small clip that holds hoses to frame, pitman arm, fluid for pump, belt for pump. Done!!
liftlawssuck is offline   Reply With Quote
Old 06-29-2018, 04:47 PM   #6
cypressbog
Go Pack Go!
[/QUOT
Thank you but I need more info to get ahold of him[/QUOTE]
His birth name is mike, his board name is 67-72chevytrucks. Search the members list for his contact info.
Old 06-29-2018, 07:28 PM   #7
Bigdav160
Bigdav160's Avatar
I've never owned a '68 (yes to '67)
It seems some '68's didn't have the accommodation dimples to take a integrated power box. Take a close up pic of your mounted manual box.
If it doesn't have the dimples some people add a spacer
or even modify the frame.
Otherwise you're looking for something that wasn't even listed as an option
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-30-2018, 08:21 AM   #8
mygmctruck1
No dimples on my frame ? whats there purpose ? I have to assume to keep the box in proper alignment ?
Old 06-30-2018, 08:37 AM   #9
frankinstein
Does some one sell the plate your adding for the PS box?
frankinstein is offline   Reply With Quote
Old 06-30-2018, 08:40 AM   #10
1968k20
1968k20's Avatar
I see the ram power assists on ebay from time to time
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 06-30-2018, 10:57 AM   #11
Bigdav160
Bigdav160's Avatar
1967 trucks had ram assist steering with the same manual box. the frame area is flat.
1968 introduced the intregrated PS box and it is fatter. So the frame horn is different in this area.
I don't remember seeing power steering being available on 4x4 in '68. Best just to look your frame to see if the box will fit. If it is flat then Captfab makes an adapter bracket.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 06-30-2018, 11:52 AM   #12
cypressbog
Go Pack Go!
Yes power steering was available in 1968. If I remember correct, the 4x4 used ram assist with the dimple in the frame.
Old 06-30-2018, 11:52 AM   #13
mygmctruck1
Mine is a 68 1/2 ton 4x4 and it's flat ? but again why the nipples?
Old 06-30-2018, 12:00 PM   #14
mygmctruck1
It appears that adapter plate is used to accommodate the 4th hole in the PS box ? Other wise have to drill a 4th hole in the frame .
Old 06-30-2018, 12:23 PM   #15
mygmctruck1
Ok ,here’s what I have.
Old 06-30-2018, 12:25 PM   #16
mygmctruck1
A couple more
Old 07-01-2018, 01:37 AM   #17
57taskforce
All about them K’s
57taskforce's Avatar
The dimples space the box off of the frame. Without them The area circled in green will hit the frame before the mounting ears on the box are tight against the frame.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 07-01-2018, 07:20 AM   #18
mygmctruck1
Than this has to be changed too , where do you get one ? I looked at LMC ,they don’t offer them?
I know this isn’t rocket science but I have contacted several outfits. Like lmc, brothers, eklers , cardid . no one seems to know about this and what I need but I knew someone on this board would have answers.
I can find one but it’s for a lifted truck and has only 3 hole to mount , mine has 4 ?
Some one point me in the right direction .
Old 07-01-2018, 08:03 AM   #19
Bigdav160
Bigdav160's Avatar
Closed knuckle steering arm. Maybe with the right combinations of tie rod ends you can make a drag link of the correct length.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 07-01-2018, 08:37 AM   #20
Mts67C10K20
Good morning
I am not familiar with your gear box in pictures
It is not the normal Saginaw box I think most are referring to
Do you know what it originally came off of
As far as the steering arm and tie rod you circled those should work
With a Saginaw box and pitman arm (see pic)
Old 07-01-2018, 05:26 PM   #21
mygmctruck1
Originally Posted by Mts67C10K20 View Post
Good morning
Thanks for your input. The gear box in the pic ,is the non PS unit . I have the PS box sitting on the work bench . The reason I am some what mystified is no one has answers for a conversion , except on this site. It looks like I have the info I now need for my PS box installation. But should I run into a road block , I’ll be asking questions once again.
