Old 06-28-2018, 09:53 PM   #1
ZEKE68
ZEKE68's Avatar
Running wires down A pillar?
Anyone have any advise about running wires down the left A pillar from the inner roof to under the dash. I don't see any obvious holes or routes.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 06-29-2018, 12:22 AM   #2
ryans69chevy
Re: Running wires down A pillar?
Hey ya go... this is the hole behind the side of the dash. You might want to remove instrument cluster for better access or else you will be on your back under the dash.
ryans69chevy is offline   Reply With Quote
Old 06-29-2018, 12:27 AM   #3
ryans69chevy
Here is the top of cab with outer roof skin removed. You can see a quarter sized hole in the metal brace above the A pillar.
Assuming you have cab roof marker lights take them off and you have access to the wire.
Old 06-29-2018, 12:29 AM   #4
bruceman1968
bruceman1968's Avatar
Post by Tx Firefighter several years ago.
Video is still up. Just click on description at the top of the video.
https://67-72chevytrucks.com/vboard/...d.php?t=463029
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
