Old 06-29-2018, 07:45 PM   #1
old51sedan
old51sedan's Avatar
MI: Lowering rear end:
In the process of installing the 4" drop coil springs in the rear of my truck. I believe while the rear axle is jacked up should be the time to install the tapered aluminum wedges. I'm not sure as to which way they go? Does the tampered end go towards the rear or the front. I guess if I let it down I would know, but wanted to hear from someone who has installed them.
old51sedan is offline   Reply With Quote
Old 06-30-2018, 07:19 AM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: MI: Lowering rear end:
I dropped my LWB 72 C/10 and never bothered with the wedges. That was like 5 years ago and no issues at all. I think those wedges are only necessary on a leaf spring rear and extreme drops where pinion angle falls outside the 3% angle difference to the trans tail shaft...?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
