07-04-2018, 10:11 AM | #1 |
69 C10 Wheel Change
I have a stock 69 c10. I was trying to put a set of Denali wheels that I took off of my wife's car on it. Can anyone help me figure out what I need to change on the truck to make this work? The wheel wont go over the hub and the studs aren't long enough. Any help would be appreciated.
07-04-2018, 10:23 AM | #2 |
Re: 69 C10 Wheel Change
Well, the first question is: are the bolt pattern sizes even the same? If so, you'd have to have the back of the wheels where the hub fits machined larger (assuming there is enough wheel material there to allow doing this without compromising the strength of the wheel) and put in longer studs. This is also assuming the offset of the wheels is close enough to allow the wheel/tire to fit on the truck without rubbing.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
07-04-2018, 01:00 PM | #3 |
Just buy adaptors around $100 on eBay. They bolt to your hub then the wheel bolts to them
70 SWB STEPSIDE 70 BLAZER 09 challenger |
