07-11-2018, 11:44 AM | #1 |
landarts
Help with 16" steel wheel hubcaps
I am trying to finish up a few items on my 3/4 ton GMC 4x4. The truck has stock 16" 8 lug rims. I am getting ready to take off and either sandblast or powder coat white. What size of hubcaps will fit the stock 16" rim? Is there a particular outside diameter I am looking for like 12" or do the 1/2 ton and 3/4 ton hubcaps fit the same. Here is a picture of the wheel. Here is link to current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=748755 Thanks for the help!
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
07-11-2018, 11:46 AM | #2 |
Moderator
Re: Help with 16" steel wheel hubcaps
You need 12” diameter caps. The 1/2 ton caps are 10.5” diameter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
07-11-2018, 12:10 PM | #3 |
landarts
Thanks leddzepp I appreciate the help, now to get hunting.
07-11-2018, 01:42 PM | #4 |
Member pickmup (Frank) usually has some very nice restored ones on hand. You need 3/4 ton PO3s - fronts specifically for 4x4 with center cutouts for the hub. Frank can do!
07-12-2018, 01:23 AM | #5 |
Moderator
No problem. I happen to have a perfect set of caps for that truck...hopefully I can buy it when you are finished with it
07-12-2018, 12:52 PM | #6 |
Heres an upclose picture of the 12" cap you're after, mine are 16.5" rims but the same cap will work on 16" rims.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
