07-11-2018, 01:00 PM | #1 |
Yet another temp gauge question
‘71 c-10. Vortec 350. My temperature gauge was unhooked when I got it. Probably because of the different sending unit. Got the proper sender but haven’t started it yet. Gauge presently reads full hot even with the battery disconnected. Does this mean that the gauge is bad?
Posted via Mobile Device Last edited by DWX 9929; 07-11-2018 at 03:12 PM. |
07-11-2018, 02:03 PM | #2 |
Re: Yet another temp gauge question
The gauge works by having 12 volt power to it and the sending unit is the ground. The more it grounds (gets hotter) the more the gauge moves to hot.
Without the battery on, the gauge can't work. If it pegs when power is on your are shorting (green wire connection) somewhere between the green wire on sending unit and the gauge. |
07-11-2018, 03:15 PM | #3 | |
Posted via Mobile Device |
07-11-2018, 07:00 PM | #4 |
I have a 1969 CST/10. With power removed the temperature gauge stays in whatever position it was when the engine was turned off. So usually my gauge is sitting a little left of center, where it was when I shut the truck off. If I come back later when the engine has cooled off, and start the truck or turn the headlights on, the gauge will swing to cold. If the green wire that goes to the sender is shorted to ground, the gauge will peg to hot. If power is removed by turning off the key and headlights, and then the green wire short to ground is removed, the gauge remains pegged on hot. When I start the truck or turn the headlights on, the gauge will move to whatever the current temperature of the engine is.
07-11-2018, 09:24 PM | #5 |
Cluster King
Try this,
Run a ground wire from the lower center stud on the temp gauge to a known good ground and see what happens. Also, pull the green wire from the sending unit, turn the key on and see what happens. If the gauge goes back to cold, then the sender is bad. More time than not when the gauge pegs full, it is because the temp gauge itself is not grounded properly. Keep us posted, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
07-12-2018, 12:53 PM | #6 |
Gauge is working normally. Guess it does stay at the last position when key is turned off. Thanks for the input!
