Old 07-12-2018, 01:45 AM   #1
noguirre71
noguirre71's Avatar
71 Steering column mounting bracket
Hey guys so i just replaced the later model steering column that the orevious owner had installed with a tilt column that i picked up from kevsclassic.
The issue im running into is the okd column was held together with a thin strip of metal on the bottom and bolted to this bracket which is bolted to the firewall. The first three pictures I uploaded shows the mount that’s bolted to the firewall. It also looks like my brake pedal may be bolted to that bracket. The last picture is what I come to find on here that I’ll need so my column won’t hang.
My question is....is it okay to remove the bracket that is in there right now? Is that correct for this 71? I’m hoping I could take it out as it would clear up much space.
Thanks guys
noguirre71 is offline   Reply With Quote
Old 07-12-2018, 01:46 AM   #2
noguirre71
noguirre71's Avatar
Re: 71 Steering column mounting bracket
Sorry. Idk why the first three pictures were rotated to the left 90 degrees.
