Old 07-12-2018, 08:05 PM   #1
jp2240
68 to 71 cab differences
I'm sure this has been asked before but the search option doesnt always work. Maybe because I'm on my phone. Anyway , other than the parking brake lever and obviously the vin, is their a difference in the cabs? I know the front clips are a little different but is the cab its self different?thanks
jp2240 is offline   Reply With Quote
Old 07-12-2018, 09:46 PM   #2
Fast68C30
Re: 68 to 71 cab differences
stuff like parking brake mount all different 68 older have hand pull brake lever under column. i want need a 68 67 cab for my build i dont want a 69 up cab actually im picky like that cuz im doing a clone of the 67 C30 i had a long time ago with a 65 C30 chassis. gonna be rough finding me a 67 68 cab. just some small things are different but nothing major and 67 and some early 68 have smaller ign switch bezel diameter also. and i think ash trays mount changed too
1965 C30 dually rolling chassis getting built with a '67/'68 body, am collecting parts for body and inside cab and 250/292 engine brackets pieces right now 2018! anything in central IL
Fast68C30 is offline   Reply With Quote
Old 07-12-2018, 10:40 PM   #3
Husker
Husker's Avatar
The rear view mirror is different also. Raised portion where it mounts
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 07-12-2018, 10:56 PM   #4
Fast68C30
Ron
72 doesnt at all
Old 07-13-2018, 05:03 AM   #5
darrellyates
This is NOT a for sale post... However, I know where there is a perfect 67 cab with a small window in sealer. I'll send you a PM. No money for me in this... I am just trying to help another out....
darrellyates is offline   Reply With Quote
Old 07-13-2018, 06:31 AM   #6
GMCPaul
Besides the above mentioned differences
Most Important is
67-68 cabs use a completely different fuse box than 69-72 cabs and they are not interchangeable. So you must use the correct year harness for under dash harness, engine harness & forward lamp harness for the year of cab you are using or cut the fuse box opening off the original cab to graft to the donor cab.
another is
The 71-72 cab uses a different gas pedal mounting than 67-70 cabs.
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 07-13-2018, 06:46 AM   #7
jp2240
Thanks for the input guys thats just what I needed to know. I just bought a 68 but its being shipped so I couldn't compare it to the 71 cab I've got. Thanks again
