07-14-2018, 02:57 PM | #1 |
CPP 5 lug conversion axle’s
Has anyone had problems with CPP’s 5 lug conversion, I originally ordered mine for a 70 C10 but it was shorter 30” exactly, and the ones I pulled out mine and it was 30 3/4 so I returned them and got mine for a 69. Are the axles suppose to be the same size?? I measured it from like the backing plate to the top of the shaft
Posted via Mobile Device |
07-15-2018, 10:52 AM | #2 |
Re: CPP 5 lug conversion axle’s
In 70 they changed the length sometime during the production run. You have to measure to get the right ones.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
