Old 07-14-2018, 05:05 PM   #1
Sawlog
3in front drop and 2in rear
If I drop the front end of my 69 3in with springs, do I need new shocks?
And if I drop the back 2in with springs, do I need new shocks?
I notice everybody drops the back more then the front. But if I go 3in in the front and 2in in the back, it will make the space between the fender and top of the tire the same.
Sawlog is offline   Reply With Quote
Old 07-15-2018, 08:56 PM   #2
PGSigns
PGSigns's Avatar
Re: 3in front drop and 2in rear
Front yes on shocks and rear maybe. For most of us it is the overall attitude of the truck and not the distance from the tire to the wheel well. The overall stance is what makes or breaks it for me.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-17-2018, 05:34 PM   #3
Kudzupatch
Kudzupatch's Avatar
3 inches with just springs is going to really limit the amount of travel you have. You will be bottoming out a lot I suspect. I would recommend looking at springs and spindles.
Kudzupatch is offline   Reply With Quote
Old 07-21-2018, 07:45 PM   #4
Mike C
Mike C's Avatar
Something seems off on your truck... They are always higher in the back than front if things are stock. I have a 71 GMC somebody heated and collapsed the rear coils on and it's STILL higher in the back...
Some trucks are OK with 3" springs, but some can't be aligned. If you really want to lower your truck, I would get a complete kit rather than trying to figure out what a PO cooked up. (F'd up?).
On mine I went with ECE disc conversion and 5 lug axles so that I could actually have some wheels to choose from. The drop disc spindles are the best way to get the truck down IMO. 2 1/2" then you can play with springs to get what you want. 4 1/2" on my truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-21-2018, 08:45 PM   #5
Sawlog
My tires in the back are 31/10.5 r15. Front tires are 235/70r15. It's stock height, just wanted the top of tire to wheel well the same on front and back.
Old 07-23-2018, 06:20 PM   #6
sweetk30
sweetk30's Avatar
and alignment might be fun getting back in spec .
as said do a combo . spindle and then the rest with a good spring . be better off in the end .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-27-2018, 07:45 AM   #7
SC1969c10
Funny to see this thread. The other night im out working on my truck so I grabbed a tape measure. The previous owner put drop spindles on the front but stock out back. My truck also measures just 2” needed in the rear to make matching clearance. Not sure if the drop spindles are 2 or 2.5”.
SC1969c10 is offline   Reply With Quote
Old 07-27-2018, 07:46 AM   #8
SC1969c10
But i would get new springs, whats 80-100 when your already going through all of the trouble of swapping springs
