BlahBlahBlah
Helper bags
Seems like a good way to go if you only occasionally run a bit heavier load on a half ton, maybe even on a 20 series truck.
What do you look for when searching for helper bags? Do you use a built in pump system like the frame dragging peeps, or do you use your home air to pump em up when you know it's gonna be extra work day for your truck? |
#2 | |
Old member
![]() Quote:
I have them in all 4 springs. Help's the handling and the loads. I have the rear ones on a compressor only no tank. Fronts have Schrader valve in front. They hardly ever need more air. I run 15/20PSI in them all the time. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Jan 2009
Re: Helper bags
I have them on my ‘07 Dodge dually and help a lot when pulling the 5th wheel for ride and stability. It’s an AirLift system w/small compressor. I installed a set (I think it was a kit from Bell Tech?) on the lowered ‘90 ext cab I formerly owned so I could pull my tandem axle car trailer without the fenders cutting my rear tires. It was plumbed w/fitting inside gas filler door (no compressor). I bought a pair of air bags and will fab mounts to install on my ‘68 GMC C15 when I do the 4-6 drop on it. I’ll install a compressor on that setup.
1968 GMC C15 SWB 1966 Chevrolet Suburban 1936 Ford 5w coupe 1939 Ford Tudor Deluxe 1951 Cadillac Coupe DeVille 1971 Avion T28 |
#4 | |
![]() Join Date: Oct 2009
Re: Helper bags
laying low
![]() Join Date: Mar 2001
Re: Helper bags
I've been giving thought to adding some helper bags to my 1/2 ton crew cab I pull our 5th wheel with. I think I would trust a name brand like Firestone or Air Lift for example.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Old member
The compressor is nice having to fill the system when ever I need it. They say not to run them totally empty so I can put air in anytime I want out back. These helper bags really help with handling to. They want tell you that but mine handle great and the ride is fantastic. I'd rather drive the 71 than my 08 Tahoe!
Junior Member
![]() Join Date: Oct 2015
Re: Helper bags
Andy, is the air lift kit 60811 that you've got mentioned in your signature for the front or the rear? And if you have the info available what is air lift kit number for the other axle
71 C/10 "Brooke" - The Rat Rod Tow Truck 98 Blazer "Hulky" - The Tow Rig - Sold 11 Regal - The DD 76 Kawasaki KZ900 - One Day I'll fix it 06 Street Bob - Soon to be Sold |
Re: Helper bags
I used them on my 05 1500 silverado shorty. It had the Hotchkiss TVS system and handled like it was on rails. I needed to tow a large skidsteer every now and then very short distances, and had to have the helper bags. I just used a schrader valve and aired them up when needed. They were a great way to increase the load capacity. I highly recommend them. Man I wish I never sold that truck.
#9 | |
Old member
![]() Quote:
Re: Helper bags
I had a '70 C/10 I used for work, had a Reading steel topper, carried tools and ladders. I installed 3/4t coils with Air Lifts inside coil bags. I just had a filler in the step bumper, kept 90# all the time, so only needed to check/fill pressure
On my '67 SWB with a 4/6 drop I plan to use bags in place of the rear coils. I want to carry, tow, don't want to c-notch, and was on the fence about going to 4" springs to give it a rake or run it more level with the 6s. This way I can have both. I might put a compressor & controls on that. Doesn't go with the era vibe but makes a lot of sense.
