Old 07-18-2018, 09:55 PM   #1
jpgl
Junior Member
8 bolt rims
want to put 2006 rims aluminum truck rims on a 1970 gmc 3/4 i tried on the rims they fit .want to know where i can buy nuts to fit that will allow me to use the factory caps.
jpgl is offline   Reply With Quote
Old 07-19-2018, 08:24 AM   #2
geezer#99
geezer#99's Avatar
Re: 8 bolt rims
Ebay has some.
Your local parts place should too.
I’ve bought some from Napa.
https://www.ebay.com/sch/i.html?_fro...ts&_dcat=33749
Ask for dual threaded lugnuts.
Old 07-19-2018, 09:28 AM   #3
Larry Weaver
Re: 8 bolt rims
Try EZaccessory.com, was cheaper than evry other place I tried.I think I had them in something like 4 days.
Larry Weaver is offline   Reply With Quote
Old 07-19-2018, 11:38 AM   #4
demian5
demian5's Avatar
Re: 8 bolt rims
My son has some extra (non-GM) aluminum wheels from his squarebody, he just upgraded to Methods.
The issue with the newer wheels (he had a set of 06 2500 aluminum's) the offset puts them in really far and close to the suspension. you may not like the look. You can get wheel spacers though that bolts onto your hubs and then you bolt the wheels onto the spacers.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 07-19-2018, 02:14 PM   #5
FirstOwner69
FirstOwner69's Avatar
Re: 8 bolt rims
Here's a thread with numerous pictures of different 8 lug wheels and links to lug nut sources.
http://67-72chevytrucks.com/vboard/s...d.php?t=330740
As stated above, the aluminum wheels you are thinking about use dual thread lug nuts. These wheels were used starting in 2001 and would have used metric lug nuts. You will find several eBay sellers who sell the SAE threaded versions in 9/16" and 1/2". If your 1970 truck has the original studs, you'll need 9/16" nuts.
https://www.ebay.com/itm/32-LUG-NUTS...sid=m570.l1313
FirstOwner69 is offline   Reply With Quote
2006 rims on a 1970 gmc.
