Old 07-20-2018, 02:39 PM   #1
QKENUF4U
QKENUF4U's Avatar
Leafs backwards ?
Got this truck almost 2 yrs ago.. Did a bunch of work along with new suspension bushings n 4" lift... Got a smoking deal on 35's yesterday n got em mounted today... Noticed my rear wheel sits way forward... I measured the leaf n its only a 1/4" differance... I'm not OCD but I definitely don't like it like this..,
QKENUF4U is offline   Reply With Quote
Old 07-20-2018, 03:52 PM   #2
liftlawssuck
liftlawssuck's Avatar
Re: Leafs backwards ?
Yea that's a common sight issue with these. It kicks the rear forward some. More pronounced the higher it is. Stock it's not noticed. Although that one seems more than usual. Might just be the angle. You can always move rear end back the correct amount to make it look line up.
liftlawssuck is offline   Reply With Quote
Old 07-20-2018, 05:06 PM   #3
Bigdav160
Bigdav160's Avatar
Offroad Design Zero Rate
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-20-2018, 06:54 PM   #4
Mike C
Mike C's Avatar
That's crazy pushed forward. I trimmed a pie piece of the front of the wheel well on my Jimmy. 3/4" wide or so at the front tapering to zero about 6" up.
When I did the semi-float 14 bolt swap, I drilled another hole in top of spring perch and moved the axle back about an inch.
In your case, the ORD zero rate as mentioned above is where I would start.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
