08-09-2018, 06:14 PM | #1 |
Torsion box cut out?
Can you tell me if the torsion box has been cut out on my blazer. I was researching The rocker box rocker panel thing and I believe mine have been cut out and will need to be re-installed.
08-09-2018, 06:42 PM | #2 |
Re: Torsion box cut out?
Yep, that's been hacked by someone. Without it your Blazer is going to have too much body flex.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-09-2018, 07:09 PM | #3 |
Ugh. It's sitting nice now, no sag. I'll have to put that at the top of the to do list. Took off fiberglass top for the first time since I've owned it and installed the bestop I picked up months ago.
08-09-2018, 07:14 PM | #4 |
wow thats mangled...good luck!
08-09-2018, 07:56 PM | #5 |
I wouldn't take your top off until you get the boxes fixed especially if the doors open and close nice. They won't after you put the soft top on if the boxes aren't there.
08-09-2018, 09:18 PM | #6 |
Yeah I'm going to put the fiberglass top back on only driven a few miles without the top on don't want it to get worse and have another problem to solve. Sucks.
08-09-2018, 09:24 PM | #7 |
Can someone tell me why anyone would cut that out?
-Bruce 1971 K5 Blazer 4WD |
08-09-2018, 09:44 PM | #8 |
I'm guessing they started and did not finish. Maybe they thought they would just put metal there as opposed to replacing the whole box. Your guess is as good as mine I'm curious as to what others will say
08-09-2018, 10:42 PM | #9 |
Thankfully the parts to replace everything are readily available and reasonable. It's also a fairly easy fix. Like others have mentioned, make sure your fiberglass top is firmly bolted on before cutting. Good luck !!
08-10-2018, 05:50 AM | #10 |
Mine were completely missing when I bought my Jimmy in 2014. At least it made replacing them fairly straightforward, nothing was in the way.
08-12-2018, 12:42 AM | #11 |
I've seen several seemingly nice full restorations on eBay over the past couple years that were missing the rocker boxes. I know they tend to rot out but have no clue why someone wouldn't replace them...
Mine were practically falling out when I got my blazer. I cut a few inches on it and it fell out the bottom of the truck only holding by the support bar and front lip. I raptor lined them inside and out when I reinstalled them. |
08-12-2018, 01:04 AM | #12 |
Thanks for the reply
08-13-2018, 11:02 PM | #13 |
Someone put fuel tanks in mine. I like the idea of the additional capacity, but not the missing structure.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
08-13-2018, 11:23 PM | #14 | |
08-14-2018, 10:05 AM | #15 |
Interesting. I am sure that I have done some "strange" stuff to vehicles over the years that I wouldn't do now. At this point in my life I see the value of structure and most likely would not be cutting something like that out!
08-14-2018, 10:51 PM | #16 |
Factory frame is only C channel - you could fully box the frame with a welder if you didn't care about factory appearances and needed the extra space below for something ..steps, tanks etc.. the square tube frame will be stiffer/stronger than any support the original tin rocker boxes add anyway.
08-15-2018, 05:26 PM | #17 | |
08-15-2018, 09:55 PM | #18 | |
Boxing in the frame is not a substitute for rocker boxes. You can box the frame in all you want but it won't prevent the body from sagging between the mounts. Last edited by stangtjk; 08-15-2018 at 10:02 PM. |
08-15-2018, 10:01 PM | #19 | |
08-16-2018, 12:05 PM | #20 |
I just bought a 72 and after looking at these pictures I believe someone has cut mine out too. How hard is it to install new ones. I'm new to blazers so I have no idea how they go. Also mine has an aftermarket roll cage built into it that goes from front to back so with that would mine still flex if the top was removed?
07 GMC Sierra 2500 compound turbo' duramax 99 GMC Yukon solid axle swapped 67 Chevy c10 small window swb stepside supercharged ls6 70 Chevy c10 suburban 72 K5 Blazer 4wd |
08-16-2018, 04:36 PM | #21 | |
08-16-2018, 04:43 PM | #22 |
Equal opportunity joke ofender
I bought my torsion boxes at GMCPauls.com
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
08-18-2018, 06:01 PM | #23 |
True. But adding another body mount b/n body and frame to shore up any flex is not difficult for anyone boxing their own frame. I had a blazer once that previous owner did both, adding the extra body mounts just below the front seat. Doors opened perfect, even after years of hard wheelin. Just another option if needed.
08-24-2018, 11:29 AM | #24 |
I think they were rusty and a PO cut em out to hide that fact. Cut them and someone who doesn't know what they're looking at wont know they're missing. Holey metal looks bad to everyone.
1972 K5 Blazer 350/350/PS/PB From GA but live in Panama City, FL |
08-24-2018, 11:41 AM | #25 |
You may be right
