Old 08-23-2018, 08:08 AM   #1
CBH
New digital dash installed and turn signal flash fast and front barely light up
If anyone can help me out I would appreciate it.
Had a new digital cluster put in my truck and the turn signals and park lights in the front and back are blinking super fast. Then sometimes the front will barely come on. Any suggestions?
CBH is offline   Reply With Quote
Old 08-23-2018, 09:37 AM   #2
TruDom
Re: New digital dash installed and turn signal flash fast and front barely light up
not an expert on these trucks (yet) but typically that means a high resistance in the circuit. So either a bulb, wire, connection or i even had a fuse with corroded connection.
probably the connection to the new instrument panel.
TruDom is offline   Reply With Quote
Old 08-23-2018, 09:45 AM   #3
CBH
Thank you I will start with the front and work my way to the cluster
