03-29-2002, 04:03 PM | #1 |
327 heads will fit... ?
OK guys, here's one for ya,
just picked up a 327 long-block for $100 and was wondering if the heads will fit either the 307 or the 350... also, the engine was running, but there is an "oil pressure" problem. the oil pressure is fine supposedly until the engine heats up... then drops drastically. any ideas? thanks ahead of time for your help ------------------ '70 C-10 Short/Fleet 350 (in the family since new) '70 C-10 Long/Fleet 307 (the Death Machine because it seems like it'll kill you to drive in it)
'70 C-10 Short/Fleet 350 In the family since new and more than 300K on the odometer! |
03-29-2002, 04:29 PM | #2 |
Open Sundays 10 till 10
they will fit a 350 307 327 400
283 262 267 305 chevy engines may not run good on smaller cube engines but will bolt on. If they are double humps they will be perfect for a flat top pistoned 350
817-846-5476 parts for sale always 30 minutes south of Dallas on I35 WWW.BBSAutoSalvage.com bbs1969@direcway.com |
03-29-2002, 04:54 PM | #3 |
Why not just build the 327....its a good mill.........69 longhorn.
http://community.webshots.com/user/hotrodhorn |
03-29-2002, 05:01 PM | #4 |
I just might longhorn, but I need to get my short-bed running first, or get decent power to the death machine... whichever...
03-29-2002, 05:21 PM | #5 |
I built 1 a few years back,in a 4 bolt block+ 040. Flattop pistons,mild cam,& a set of LT1 staight plug castings. Dropped in a 72 long step,with a 4 spd saginaw(monza,3.50 first),& 3.73 gears).....one runnin SOB,she would pull a load like nobodys bizz,& runnin empty was fun to play with......69 longhorn.
03-29-2002, 05:57 PM | #6 |
hm reminds me, i just remembered i know of a 305 monza thats gonna get scrapped at a local towing yard, i can get the tranny and bellhousing out of it, hmmm.... !
03-30-2002, 10:11 AM | #7 |
Just an Old Mr Goodwrench
Your oil pressure problem is likely a main bearing wear problem. The oil has more viscosity while it's cold, so the excessive space between the bearing surface & the crank will hold pressure with the higher vis. When the oil warms it thins out & you lose pressure. Stopgap measures include running a high viscosity oil (20/50 etc.) But you still have a problem that won't go away. Rebuild the 327 and you'll have a nice set-up Lee
------------------ 1969 Custom 20 Longhorn 1970 CST 20 Fleetside 1950 Plymouth Special Deluxe 1991 Jaguar Sovereign 1992 Mazda Miata 1969 Triumph Bonneville 1964 Harley Sportster
1969 CST 20 Longhorn 1970 CST 20 Fleetside 1991 Jaguar Sovereign 1992 Mazda Miata |
03-30-2002, 10:18 AM | #8 |
Worn cam bearings will also cause oil pressure loss after warm-up.
------------------ Yeah, that's right. My name is Randy too! WWW.Randysrods.freeservers.com 1970 Chevy C-10 shortstep 30 Ford Model A Coupe 4 inch chop, 350, GMC 671 blower-Hell yeah it's fast! 87 Harley Sportster(couldnt get a 350 to fit) Self Propelled Lawn Mower Built in USA!!!! Virginia Beach, VA. |
03-30-2002, 10:25 AM | #9 |
If the heads have 2.02/1.6 valves they will NOT work on the 265,267,283 or 307. You will need a motor with the 4" bore. With that said, most likely they are 1.94/1.5 and will work fine ond any of the motors.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
03-31-2002, 08:21 AM | #10 |
LOVE THOSE 327s...........
Kurt in Durand, IL |
