Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 09-05-2018, 05:49 PM   #1
hkopp
79 C70 with hard brakes - bad hydro-vac?
I've been a member for a while, but usually hang out in the 60-66 k10 area. I have a 79 C70 with hydro-vac that I recently acquired. Its brakes are nearly non existent and hard, and require pumping of the peddle then pressing VERY hard to make the truck stop. I'm assuming its a bad hydro-vac unit under the side step, has anyone experienced this before? I see reman units for around $160 with a core, but would rather hear some feedback before I start throwing parts at it. I've had a C70 in the past and when working correctly the hydro-vac brakes nearly throw you thru the windshield, even with a full load.
Any troubleshooting procedures or pages dedicated to this, or is this a common symptom of a bad h-vac? Thanks!
hkopp is offline   Reply With Quote
Old 09-05-2018, 06:22 PM   #2
sweetk30
sweetk30's Avatar
Re: 79 C70 with hard brakes - bad hydro-vac?
had one that some one took out the check valve inline to the booster from the engine vac port . brakes only half worked good after a doo hard pull and decel building vac .
put a new valve inline and all was good .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-05-2018, 08:42 PM   #3
5Tractorguy
5Tractorguy's Avatar
My '61 5000 has a Midland Hydro-vac. Same symptoms with yours when I first got it. I used to have to pump the pedal twice to get good brakes, then a couple, then I took it for a drive one day and no amount of pumping would stop it.
Sent it to DS Parts Co. in Bluefield VA for a rebuild, now I can stomp on the pedal and leave dually skid marks on the road.
On those re-manned units.... make sure you call before you order! I have an uncommon Midland unit and Summit just so happened to show one on their site. After 3 weeks of not receiving it I called and apparently there was 0 in stock. They had to wait for a rebuildable core to come in (who knows when) to the Cardone Co. so it could be rebuilt and sent to me. DS had a 7-8day turnaround on the rebuild, ran about $260 with shipping.
Jake
5Tractorguy on Youtube
5Tractorguy is offline   Reply With Quote
Old 09-05-2018, 09:55 PM   #4
hkopp
Thanks for the replies. Good to hear someone had the same issue and a booster fixed it. I'll check to make sure everything is there, but since I have zero boosted brakes ever, I'm pretty sure no vac is being stored. Time to remove it and see if it'll hold vacuum on its own or if it has brake fluid in it.
